Old 09-25-2016, 10:35 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
When you wrap the teflon tape make sure you wrap it tight and wrap it in the direction the threads are going.
Or..when looking at the end of "pipe" put tape on clockwise.
While the paint is off the outlet hole of tank, examine it very closely with a magnifying glass, etc. for a crack radiating from the threads.
Or the steel plate solder-to-tank being the culprit.
Old 09-25-2016, 11:57 AM
ambrola's Avatar
ambrola ambrola is offline
Thanks, I will do that. I am sure the leak is coming from the bowl. It's very loose. You can move it with your fingers. Does anyone make the brass fuel line? Mine has a rubber hose on it now. Since I will be taking the fuel out, it would be the perfect time to fix that?
Old 09-25-2016, 01:04 PM
just keep the rubber line, the hard line is more trouble than its worth.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-25-2016, 01:20 PM
Merk Merk is offline
X2
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 01:35 PM
ambrola's Avatar
Well, that was easy.
Old 09-25-2016, 02:31 PM
Unless your going for a show quality resto as others have said keep the rubber. This is what I have on my O. I like the clear stuff, you can see if the fuel is flowing.
Old 09-25-2016, 05:50 PM
ambrola's Avatar
Mine is black and cracking. Now I will go with the clear. Thanks for that.
Old 09-25-2016, 06:24 PM
I got the fuel line at O'Rielly's off the lawn mower parts rack if that helps. The brass fittings came from Lowes if memory serves.
Old 09-25-2016, 07:12 PM
ambrola's Avatar
I have the fittings on the tractor. I can just reuse them?
Old 09-25-2016, 07:49 PM
You should be able to reuse them, just posted the info if you needed it.
