Old 09-29-2016, 09:33 PM
Tim.E's Avatar
Tim.E Tim.E is offline
John,
Possibly a wide frame(128 style) gear drive,K321/14hp, frame stretched about 3.5 inches,super steer axle,3 turn steering gear,4 bolt front hubs,3 point hitch w/12 volt linear actuator,headlights,round fenders(off a Power King) 8-16 rear tires/4.00x10 front,20% underdrive,red and white kinda thing.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 09-29-2016, 09:34 PM
Tim.E's Avatar
Thanks,Jay.
Old 09-29-2016, 09:41 PM
Tim.E's Avatar
Twoton, Your hubs look great!
Old 09-29-2016, 10:26 PM
Tim, I'd have to check, but I *think* that a set of Lo-Boy hubs will fit..... If I remember, I'll go look at my parts stash and see.
Old 09-29-2016, 10:41 PM
Tim.E's Avatar
Thanks,J-Mech.
Old 09-30-2016, 12:10 PM
IHinIN IHinIN is offline
Originally Posted by Tim.E View Post
John,
Do it!!
Sounds like an awesome tractor.
Old 10-01-2016, 09:55 PM
Tim.E's Avatar
Disclaimer: I would not be "butchering" a good 128 for that build,it would be more like taking a bunch of parts and "building" a nice tractor.
Old 10-02-2016, 01:55 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
John,
Saw these on my local CL:
https://pensacola.craigslist.org/grd/5781285770.html
And remembered this post.
Old 10-02-2016, 07:21 PM
Ok, so I had some time to go play with a set of LB hubs and a CC axle. The LB hubs use a 1" shaft (which I knew) but the spindle is just about 1/4" longer. I put one on a CC spindle and it will work, but you will have to make a 1" diameter spacer about 3/8" long with a 3/8" hole in it then use a longer bolt. It will then work fine. Or, you could cut off and make longer spindle shaft. Your choice. So, while they aren't a direct fit, they will work. May or may not be cheaper or easier to acquire, but at least you have the information now.
Old 10-02-2016, 07:46 PM
Tim.E's Avatar
J-Mech, Thank You so much for taking the time to check that for me.That is very good information,and a good option for 5 bolt hubs.
Double07,Thanks for the link.I already have 2 sets of Power King fenders,,I think I gave about $50 per pair.
