Old 10-02-2016, 09:19 PM
HydroCub149's Avatar
HydroCub149 HydroCub149 is offline
Im going to make it wider by cutting and re welding it with a 2 inch wider piece of steel
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂
Brinley PP-100 plow
Cyclone Rake
Old 10-02-2016, 09:27 PM
All you have to do is cut the ears off where it mounts to the frame, and shim them out equally per side. Not really sure what your thinking, but that's the easiest way....
You will have to do some bending on the rear mounts so that they will fit right, and IIRC, make the notches where it attaches deeper.
Your really better off trading someone plows or frames.
Old 10-02-2016, 09:28 PM
It's not long enough either.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-02-2016, 09:29 PM
Ok.... it's the other way. I couldn't remember. The NF mounts are shorter... I knew they were different length, but couldn't remember which way.
Old 10-02-2016, 10:06 PM
If you do that the sub frame will be too wide for the main frame.
Please find the correct one for your machine and pass the one you have to someone who needs it, they aren't making them anymore.
Old 10-02-2016, 10:40 PM
Okay I wont vichously cut and abuse my plow subframe ill call the local bone yard tomorrow the guy that runs it has a quite a few hes parting out. If I dont find one before thanksgiving break its the plasma cutter and welding wire for that poor subframe
Brinley PP-100 plow
Cyclone Rake
Old 10-02-2016, 10:45 PM
Check with him first....good plan!!
You could also post in the wanted section of the forum if the bone yard does not work out.
