The stub on the driveshaft does fit in the rear coupler for sure. Looks to me like the rear of the shaft is hanging free, supported by the SOLID front coupler with a pin through it. If you force them together, you're going to bind up everything.
I installed a new coupler at the engine and a new driveshaft. it has very little wobble at the hyd end of shaft. With the shaft centered on it's wobble (vertically) The center of the shaft to the center of the hyd shaft is about 7/16
off center. I'am going to remove the motor today and take the oil pan off, It should have a part number embossed on it. I was told that Kohler made oil pans that would make a difference in height.(For other equipment). Or maybe Kohler changed the block on the k301's b/4 retiring this model. |
I don't know what's wrong with your drive line alignment but I'd fix it before I put the tractor in service. If you don't, you'll likely wind up with another drive line destroyed.
before you take it apart you should post some pics of the front of the driveshaft and where the engine mounts to the frame, it might help give us a better idea of where the problem is.
Look at this page. Could be your problem?
https://www.partstree.com/parts/kohl...an-0209015952/ If you change pans, make sure your dipper doesn't hit the new oil pan. |
Driveshaft looks to be too short,The pin does go in the hole.You can try loosening all 8 bolts on the tranny and see if you can move it up for better alignment.And yes,there are 8.
Up to 534 and counting... I give up updating my profile! |
OK, I loosened all 8 Bolts at the trany and only could get about .050 difference in height, And in the pic's of driveshaft the motor is not Bolted down or the end would be in the coupler. So I removed the motor again, Took the oil pan off and the number embossed on it is 47 475 01. I could not find any info on that number. maybe one of you so helpful people would have a oil pan that you could measure the thickness of the pan were the motor mount ????
The bosses on my K301 out of my 122 are 1 1/16", maybe 1/32" more. My eyes and the light weren't good. I know it was less than 1 1/8".
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Thanks, my oil pan also is 1.062, I am stumped the only thing left to do is to shim the motor in front to lineup with hyd unit and use the modified shaft fix with u-joint and flex plate at motor, It's the only way to insure proper alignment. I work in a machine shop so it will be a piece of cake.( I hope)
Lets see a picture of where the shaft attaches to the engine.
| Tags |
| 109, driveline problem |
