Old 10-26-2016, 11:10 AM
Shouldn't be too bad of a job, anyone know about reinstalling and timing the balance gears? Gonna check them, and get out the service manual.
Old 10-26-2016, 01:39 PM
dont....really.... i have a guy that just made mandrels to balance k series engines on his balancer if you dont want it to shake that bad....but its a single..and luckily most of the kohler cranks have holes in the weights, and i dont have money to go looking through old big block motors out in the rain for heavy metals...he used to balance little briggs and honda cart motors that would spin up to 10k rpms, (he also built drag race engines in the 50s 60s 70s..... but his mandrels wouldnt fit the k series, so he had a friend make some different ones for the k series crank... i was gonna offer it as a service here soon once we get it perfected...like i said about the holes too, cheaper than ones that need heavy metals....let me know if interested..?
mike
just my opinion
Old 10-26-2016, 02:12 PM
mike
just my opinion
thanks for the info Mike, sounds good.
Old 10-26-2016, 02:37 PM
So.... a mandrel is basically a shaft. How does a mandrel balance an engine, and why would a bone stock "low" RPM engine need balanced? Hell, I take balance gears out when I rebuild them and so do 80% of others who rebuild them regularly.
Old 10-27-2016, 11:32 AM
Got the pto off, along with the bearing, got the basket pulley set screws out, I drove the key way back as much as I could, still not coming off.
Old 10-27-2016, 12:48 PM
You do know there should be two set screws in each hole? One on top of the other?
Did you pull the flywheel?
Old 10-27-2016, 12:52 PM
Mike, he says he got the PTO off. Basket pulley is what sounds like is stuck. Only two set screws in it. No stacked ones.
You need the puller Jeff makes for the pulley.
Old 10-27-2016, 01:27 PM
Yes the pto is off and the pulley set screws are out, the flywheel is still on, that puller would be useful right about now.
Old 10-27-2016, 01:52 PM
Yeah, went brain dead.
Old 10-27-2016, 07:55 PM
Engines free, loosened flywheel and it turns, assuming something is holding it like the mouse nest.
