Old 11-15-2016, 12:02 AM
Cubbie102's Avatar
Cubbie102 Cubbie102 is offline
My 102 has a metal tag on the rear diff left side of the cover with serial number.
Old 11-15-2016, 12:24 AM
Manfjourde's Avatar
Manfjourde Manfjourde is offline
Here's a pic of the rear
Old 11-15-2016, 01:26 AM
Originally Posted by Manfjourde View Post
when I turned it over the piston is stuck
How can the piston be stuck if you were able to turn the engine over?
Old 11-15-2016, 10:53 AM
Manfjourde's Avatar
Cranked it, turned the key, tried to turn it over. Whatever it would be, when I looked in the plug hole the piston wasn't moving.
Old 11-15-2016, 11:43 AM
Sounds like you have a broken connecting rod, was there any oil in it? If so how much? The block should be fine hopefully.
Old 11-15-2016, 01:21 PM
Manfjourde's Avatar
When I checked the stick it was dirty but almost full. I hope to dig into it a little more and see. Would a rod be something I could replace? I'm fairly new at this stuff.
Old 11-15-2016, 01:28 PM
Terry C's Avatar
Terry C Terry C is offline
It's hard to see the piston thru the plug hole, plug is not over the top of the piston.
If you have air moving then your rod and piston is intact.
Go get a head gasket and remove the head and check for proper movement of the valves
Sand the head flat and put it back together.
Then put some gas in it and fire it up.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-15-2016, 02:04 PM
Manfjourde's Avatar
Doesn't sound to bad at all and thanks! So what am I seeing when I look through the hole. What tool is best to be sure the head bolts are properly torques? What do you sand it with?
Old 11-15-2016, 02:39 PM
Terry C's Avatar
Go to the technical library here and page down and you will find a tutorial
http://www.onlycubcadets.net/forum/s...ad.php?t=45286
Terry
3225
Old 11-15-2016, 07:29 PM
Depending on what head is on the engine, you're probably seeing the top of the engine block between the valves.
You will need a torque wrench.
