Old 12-08-2016, 10:02 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
I set things against front of the box,I don't like "missiles" in the event of a
panic stop.
I'm old enough I don't accelerate fast, so no worry that they go reward.
I like the tote idea for inclement weather, keeps the goodies dry.
I was on a job years ago and a guy had his tool box in the box of his truck, he went off the road and the tool box hit him in the back of the head killing him.
That was a great posting.....reminded me of that.
Old 12-08-2016, 12:13 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Got an Access brand roll up tonneau cover attached to a toolbox on my rig. Had three other brand covers over the years like this one the best. Rolls up and gives me full access to the gooseneck and the winch to haul up non running Cubs. I have a drop in liner that has inserts I shove a 2x6 in to secure small cargo. Have a spray in but dented the bed when an engine fell off the hoist denting the bed.
-Rick
IH 782
IH 126
CCC 1863
Old 12-08-2016, 01:29 PM
Dirty Steve's Avatar
I have used a spreader bar and rubber mat in the bottom of the box. All good!
Old 12-08-2016, 07:12 PM
Merk Merk is offline
My truck bed is sprayed with a Rhino lining plus it has the rails that hold my 5th wheel and goose neck hitch. Item don't slip with the Rhino lining.
Project Uncle Dick
Cub Cadet 70
Old 12-08-2016, 08:20 PM
I've got a truck with an extang tilt tonnea cover
and a heavy rubber mat floor plus I have a box with ratchet straps that I usually use to wedge stuff against the wall of the truck since it is heavy enough it doesn't go anywhere. If the stuff does slide I can just prop open the top and get to it. The expanding metal bar is a good idea.
Old 12-08-2016, 08:43 PM
john hall's Avatar
Thanks for all the good suggestions. I forgot to mention this is a roll-up style with a rubber bed mat. I had in my mind some sort of cargo net, but since none of you do, its probably not the best idea. The 2x6 would be the cheapest and probably work fine for groceries. Yeah I know, really heavy stuff needs to be against the cab to start with. I may look into the bed extenders--they seem to run about $250. Are they securely bolted in place or can you lift them out for loading? Probably the largest and heaviest thing he will routinely deal with is a set of golf clubs--he's "retired' from baseball.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
