Old 12-21-2016, 10:32 PM
chief915ky's Avatar
chief915ky chief915ky is offline
Ok. Yeah, that does seem excessive. Your right. In my defense, most questions on this board come from people with no idea what is or is not normal.
I'm pretty sure that thing has a knock in it. Obviously it's a video and I'm not there, but pretty sure I hear it. That much blow by, a knock.... I'm betting on broken or burnt piston. Do a compression test. If your one of those guys who believe in a leak down test, do that too. I bet you find the cause pretty quick. Smoking quite a bit too unless it's just super cold in your garage...
No problem, I totally understand it's hard to diagnose through words alone over the internet LMAO....That's why I wanted to put up the video, now we're seeing and hearing the same thing. As they say, "a picture is worth a thousand words", I'm not sure how many a video is worth.
As far as the knock....maybe..... sometimes it sounds like it has a slight knock and sometimes it actually sounds great. The engine was completely cold in the video.... hadn't ran all day and it was about 35 in the garage.
The smoke.... yea it smokes a lot for the first couple minutes it's running, but goes away visually after a few minutes, although you can still faintly smell burning oil even if you don't see the smoke.
The engine in the 682 is supposed to be good......Supposing that it is, I am at a little bit of a cross roads on where to go from here.
I can use the 682 as a parts tractor and make the 782 as nice as possible. Swap engines and whatever else the 782 needs.
I can rebuild the 782 engine....but there's not a lot of benefit here, other than having a rebuilt engine....the 682 is still in rough shape and I'm a few hundred poorer at that point.
1974 Allis Chalmers 712S
1955 Allis-Chalmers WD45
Old 12-22-2016, 08:07 AM
Well
I'm not convinced it has excessive blow back,---------- yet.
pulling an oil fill cap off on a warm/hot engine will usually give you oil in yer face!
kind of like looking @ a nozzle of a garden hose and pulling the handle, then thinking Duh,that was stupid.
I hear the rattle John hears, but be advised the valve train on those things are noisy,some more than others.
I'd go slow in calling it a bad engine, till you warm it up and check things out.
With the air cleaner element removed, a hot engine will puff a small amount of air but not slobber oil out of the crankcase vent as John said .
Go slow and methodically.
Old 12-22-2016, 09:34 AM
Well
Glad you saw this and posted.
Like I said, been a while since I pulled the cap off a running one. You don't seldom do it for this very reason.... plus like you said, on a hot motor it will spray oil everywhere.
Like I said, a quick compression check will tell a lot.
Old 12-22-2016, 12:16 PM
john hall's Avatar
40 years ago I decided to check the oil in my go-cart--with it running. Lets just say mama wouldn't let me in the house. Some lessons you never forget.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
