Old 01-22-2017, 01:45 PM
SuperIH's Avatar
SuperIH SuperIH is offline
I was Delayed getting back to her... that darn "Life Thing" got in the way.. Finally got a break in the weather and spent most the day yesterday playing with her... and "the Tractor Gods" have smiled down upon me once again.
.. after sitting for 3 to 5 years... Yes, She's Alive and Well!
Here is the link to my follow up YouTube video.
Any and all comments is Greatly appreciated, Thanks Very Much for all the Great advice and input... "Book 'em DanO'"
https://youtu.be/zJCLPq9etvk
Old 01-22-2017, 02:02 PM
john hall's Avatar
Sounds good! Time to drive it around and see how it performs. Be sure to check for loose or broken rear end mounting bolts as has been suggested. At your leisure, read up on the 60" Haban Deck and the issues unique to them. Not saying they are bad or anything, love both of mine. But they are set up a little differently and due to there great weight cause some unusual wear on the mule drive/lift. If you have no idea about how the hydro was maintained consider changing the fluid. At minimum crack the drain plug and see if the fluid is milky. If not, you can probably get by with changing the filter. Plenty of good reading on here on that series machine (and its close relatives).
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-22-2017, 02:53 PM
Sounds pretty good. Change the oil and filter on the tranny. If it's been sitting for 3-5 years it has a ton of condensation in it.
Old 01-22-2017, 04:22 PM
Dirty Steve's Avatar
Sounds pretty good. Good job saving it.
Old 01-22-2017, 07:03 PM
I like the sound of the magnums, keep us posted on your updates.
Up to 534 and counting...
Old 01-22-2017, 08:08 PM
Terry C's Avatar
Terry C Terry C is offline
Good save
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-23-2017, 10:14 AM
SuperIH's Avatar
Thanks for the Vote of Confidence Guys. Now I have a few Questions about the 2072 I trust you can probably answer easily enough...Here Goes..
1) Probably a Really STUPID Question but I'm Curious , WHY is it even Called a 2072 if it is in fact the same as the 1872 and the other Supers, except for the engines used in the others?? What does the second # 72 Stand for anyway??? I know the 20 is obviously the HP but in most other garden Tractors the second # usually stands for the Deck Width size... not the case here..So What is the significance of the # 72 ?????
2) I've Been searching for a Manual on the 60 inch Deck and 54 Inch Plow , no luck. Any ideas on where I can get one.
3) Exactly what type of Hydro Fluid should be used? Can I use the same Tractor Surply Universal Fluid I put in my bigger farm Tractors?
4) As I said in the video the Brakes are NOT there at all. I will try the adjustment procedure but if I need new Pads where can I get them?
5) I'm sure I'l have more questions as I get into it. Should I start a new tread for this or continue here?? Thanks for all the Help.
Old 01-23-2017, 12:12 PM
Haban 374 deck manual number is 772-4065
http://tinyurl.com/gl9cgyc
http://www.onlycubcadets.net/forum/s...ead.php?t=7434
Old 01-23-2017, 12:42 PM
Terry C's Avatar
2072=20hp
1872=18hp
1410 Napa filter, fluid you mentioned will be ok for the rear
Steve gave you the deck info
Check the brake pads first before worrying about it
Couldn't tell you what the 72 stands for just a number I think
Terry
3225
Old 01-23-2017, 02:36 PM
john hall's Avatar
We argue what fluid to use just for fun!
I use CaseIH Hytran if I have it. If not I use Deere HyGard. A lot of guys use store brand oil that meets HyTran specs. Any of those 3 should be fine.
Make sure your brakes aren't rusted up and and free floating like they are supposed to.
2072 w/60" Haban
