Old 01-22-2017, 12:59 PM
If you take the top cover off, you will see that the outer pulleys have a hex top. Not the nut mind you, but the pulley. The center one does not. You can hold them there.
Old 01-22-2017, 05:48 PM
Originally Posted by DoubleO7 View Post
What I have done with great success on the narrow frame decks is:
Use a pipe wrench up close under the blade. You don't want to crush the "can" that is on some spindles between the blades and the deck itself.
Let it swing against the deck perimeter so that it will hold the spindle while you use the 1-1/8" wrench.
Put a cheater pipe on the 1-1/8 if needed.
The above has not been J-Mech approved.
I've always used an impact as well.
Old 01-22-2017, 10:38 PM
bocephus1991's Avatar
Kroil oil and a impact wrench!
Brian
Old 01-31-2017, 05:38 PM
1250LC's Avatar
1250LC 1250LC is offline
Originally Posted by bill682 View Post
You can remove the deck belt cover and hold the spindle nuts with a 1-1/4" socket. Good idea to clean under the cover while it's off. I think the manual even states this to remove blades.
That's the trick. The pulleys are keyed to the spindles so if you hold them with a 1-1/4 " socket from the top of the deck that will hold the spindles from turning and you can loosen the blade bolts underneath.
Tags
1250, 44a, mower blade
