Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Guess it depends on who you ask, us old guys or the newbies.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I was always told and taught that it stood for winter weight. I never did ask for specific temp ranges just assume 32*F and below the first number is its viscosity rating and the normal operating range is the 2nd viscosity rating..
They measure multi-viscosity oils by measuring the time it takes for a standard amount of oil to pass through a standard orfice at 2 temperatures. The first 32 degrees (winter) the second 100 degrees. Basically 10w-30 flows like straight 10 weight at 32 degrees and flows like straight 30 weight at 100 degrees. Now that's only a flow test, no other pressure or wear tests. So straight 30 weight will still out perform 10w-30 in most other tests.
IH 782 with Kt 17 series 1 108 |
And like I said "what is this winter you are talking of "
If you live in or near the Tropics ,( 80 to 90 degrees all year round) Im confused ? Guess you need 10 Summer 40 Garden Tractor- is becoming- riding lawnmower too Oh and last night I called autozone ,I asked for 80 winter 90 oil ,"you mean 90 weight" he asks "no 80 winter 90 " says I...long pause ,"come on in we will fix you up "he says and click |
The "naming" of the oil has nothing to do with the place you life. It simply states that at operating temp the oil acts like a thicker one would. And at ambiant/cold temp it's acting like a lighter oil would...
You can call it whatever you eant. But I'm gonna stick with what the guys that actually design and produce it say |
