Old 03-11-2017, 03:09 PM
Is it possible to remove the voltage regulator and clean it if the contacts are sticking?
YES, it is possible BUT....not the smartest thing to do. IF.....you are looking for the best long range fix, replace the V/R.
Old 04-02-2017, 09:38 PM
jcsmith jcsmith is offline
Default worn wire insulation
I had a similar problem that turned out to be 2 wires under the frame that had worn thru the insulation and bare wire would ground against the frame and/or each other.
Hope you got it fixed.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Tags
cranking, electrical, key, smoke, starting
