Old 03-04-2017, 11:24 PM
Originally Posted by mortten View Post
Looking at the picture Dirty Steve put up the 7 must be different than the 10 and 12. Join
It is.....
Old 03-05-2017, 07:41 AM
ambrola's Avatar
ambrola ambrola is offline
I made mine for the "O" Ronnie. But I'm not going through the whole thread trying to find it. Sorry... I used copper tubing. Pretty easy to make, just take your time, so not to kink it. Never good when it gets kinked.
Nuts I got from "somebody"
I will look through it and see if I can find it. How do you make the flange on the ends? That would be the only thing I don't know how to make? I had a spare and used it just last week on my other O. It had a rubber line.
Page 25. Just says you made it and a picture.
Old 03-05-2017, 08:35 AM
Ronnie there's no flange on the end, just straight cut. I might have one I will look
Old 03-05-2017, 08:40 AM
Ronnie:
The rubber bushings, when compressed by the nut, provide the sealing. As previously stated, it is a straight cut ends.
Old 03-05-2017, 09:54 AM
Terry C's Avatar
Terry C Terry C is offline
PM Lew, he made some up awhile back.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-05-2017, 10:46 AM
Ronnie:
The Fuel Line Sleeves are still available.
Old 03-05-2017, 12:22 PM
ambrola's Avatar
Thanks Alvy, I should have known that.
Ronnie:
That would be great.
Thanks for that. Where do you get the nuts?
Already tried Lew. No luck.
Ronnie:
Thanks again.
Old 03-05-2017, 12:29 PM
Squirrels have nuts, so do chipmunks, you also need the elbows to put your nuts on.
Case IH has them too.
Old 03-05-2017, 02:15 PM
ambrola's Avatar
This is just too complicated. I WILL find a used one. If not, I will put rubber on it and be done with it.
Old 03-05-2017, 02:26 PM
Put a rubber hose on it and run it. That's what I would do. Forget the metal line. Isn't worth the hassle.
