Old 03-19-2017, 07:41 PM
Only 1853 questions to go.....
Up to 534 and counting...
Old 03-19-2017, 07:59 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
That might be enough, but no guarantee.
Cannon.
Old 03-20-2017, 11:08 AM
Cannon51's Avatar
This morning I finished cleaning the gasket surfaces with a wire brush on the drill and some carb cleaner. The tube of "Ultra Black" oil resistant is almost empty so I will pick up another tube of it today. I have some gray but it doesn't say oil resistant on the package. Should I worry thar the paint is pealing inside the housing?
Cannon
Old 03-20-2017, 03:23 PM
I've used Ultra Gray and never had a problem. Don't worry about the paint inside. Let it sit for a day after you silicone it before you fill it with oil.
Old 03-20-2017, 07:04 PM
Cannon51's Avatar
Since I had picked up a tube of Ultra black I used it. I watched a YouTube video about using it. It said put a bead on, let it set 15 minutes before bolting it on, tighten the bolts lightly, wait and hour then torque to spec. Sounds a little Voodoo like but that's what I did. I torqued it 3 times, 10,25, then 30. I'll wait til Thursday morning to put the new filter on and fill it up. Thanks for your patience.
Cannon
Old 03-20-2017, 07:06 PM
I think you will be good to go. No warranty expressed or implied.
Old 03-21-2017, 10:54 AM
Cannon51's Avatar
The tubes came in yesterday afternoon so this morning I took a couple of Advil for my back and took the tire off the rim. At some point I need to start paying to have this done. I was surprised to find the rim this rusty, maybe somebody put some kind of sealer in it. Anyway I need to wire brush the rust off and get some paint on it before I put the tube and tire back on.
Cannon
Old 03-21-2017, 11:24 AM
I don't even bother doing tires anymore. My tire guys does them for about $5.00 and no charge if I buy the tire from him. My back hurts just looking at that pic.
Old 03-21-2017, 01:02 PM
Cannon51's Avatar
I know I should go ahead and do the other tire now but I'm not going to. I'll do it when it starts leaking. I got it wire brushed and primed with rusty metal primer. I need to read the primer can and see how long I need to wait before I paint.
Cannon
Old 03-21-2017, 05:19 PM
Tire work is not hard work if you work smart.
I'll admit to being over 70, and do them all, from a wheelbarrow tire or motorcycle to 38" tractor tires.
I'm no superman, I just use my head and tools and leverage to accomplish what I need done.
Some day I'll slow down when I'm old, but not yet.
If it's heavy, I use the loader, chain fall or come along, if it is difficult to turn, I use a longer bar.
No need to fight anything, just work smart.
I do admit experience helps, but today we have the internet for things one has not done previously.
