Old 03-21-2017, 08:12 PM
I ran my Workhorse Loader off of the cubs hydraulic spool on my 149. It can lift 400 lbs, which is what I wanted it to do so I can save the axle and spindles. You might be able to set something up like that only with QA fittings so you can go back and forth between your loader and your mower, if that is your intent.
Old 03-21-2017, 08:16 PM
Shaner Shaner is offline
Neither is garden hose....
Flow rating the pump isn't necessary. You just need a coupler for that size of hose. A regular Pioneer will be fine. If they'll flow 30+ GPM on a big tractor, I'm sure you can suck 6 gallons through them.
I wouldn't do what your doing.... but that's me. I'd leave the pump, tank and the valve on the tractor and put couplers on the loader. But I'm sure your wanting to be able to use a mower or something. Your getting into more trouble than it's worth if that's what your after. If you just looking to take the loader on and off...... do as you wish.
I would do that as well...but the reservior for the hydraulics is part of the loader frame. Id like to make the loader removable because sometimes its a pain to have the loader on for certain things. The kwik way loaders are removable that's why I want to make mine removable. I was wondering if larger Pioneer couplers would work. I'll have to go to the hydraulic shop and see what they got
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169.
Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3.
Old 03-21-2017, 08:29 PM
I know the tank is in the frame......
That I have every seen the Kwik Way loader (for a Cub Cadet) wasn't easily removable unless someone modified it. If you know of something I don't, post pics.....
So...... how exactly do you plan to make it removable if your leaving the upright "tank" and lower frame in place? You planning on just removing the pins at the top?? If so, that' won't be any more fun to take off and put on than just removing the whole thing...... Just leave it on.
Old 03-21-2017, 08:47 PM
The newer style kwik way loaders come off of the subframe with two pins. It's the non self leveling loader that they still offer for newer simplicity/ariens tractors.
And yes the upright would still be the reservoir for the hydraulics. The pump would stay on the tractor. Hence why I asked about the quick connects for the hoses running from the pump to the valve and reservoir. This loader will be removable. I'll be fabricating mounts to make it similar to the kwik way but using my Johnson loader.
Here is a pic of the kwik way. You can see the bottom of the upright, there is a hitch pin. That comes out, then those bars are disconnected that run to the front end of the tractor and the loader is supported on stands. Then you simply back out of the loader just like the big ones. That's what I want to do with mine.
File Type: jpg 457979d1361588298-kwikway-fel-p6231749-jpg-1.jpg (37.9 KB, 69 views)
Old 03-21-2017, 08:48 PM
Here is another pic of just the subframe with the loader pockets so you can kind of see what I'm talking about
Old 03-21-2017, 09:51 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
I have that very same loader. I made a new subframe for our dx22e to put the loader on. Stashed the subframe and pump in the shed and just put 3/8" pioneer couplers to run the valve. Also got rid of that crappy little spool valve and put a joystick from surplus center.
That loader is even hard on a tractor made to handle a loader, really bad on front tires. The loader sits in the shed most of the time. Its really too small to be worth putting on the tractor. I have yet to find a job it can do that my R bucket cant to better/faster. Except of course loading dirt into the cemetary truck.
Id do like J mech said n just buy the cplings from surplus center for the size of hose you have. The other thing would be to mount the coupler on the pump instead of splitting the hoses. That leaves the hoses with the loader.
1- 1200 in pieces
1- 1864 in pieces
Old 03-21-2017, 10:08 PM
Originally Posted by tasnyder83 View Post
Shaner,
I strongly advise not putting a typical quick disconnect on the suction side of a pump. As J-Mech mentioned, they will flow large volumes, but this is under 1500+ psi. Hydraulic quick connects will simply not flow this much at atmospheric pressure. I have spent the last 13 years designing hydraulic lines routings for mobile equipment. We typically stay away from quick disconnects for that reason. With that being said, we do use a snap to connect fitting that is not as restrictive. The downfall is that it requires a special tool to disconnect and it doesn't have the check valves that stop the flow. Probably not the best solution for your application. I'll talk to some of our fitting experts at work tomorrow and see if there is something else you can use. If you need help figuring out the flow rate of the pump, see if you can get some numbers off of it and I can help figure that out. Your pulley sizes would help also.
Tab
While I'm sure you do a very good job at your job..... I think your delving too far into this, or overthinking it. I promise, the pump is under 8GPM. If it's over that I would be absolutely shocked, as the typical size is about 6GPM.... and that's at full flow, full speed. While I agree that a coupler would be restrictive on a suction line, I'm pretty sure that a large quick coupler will be fine sucking the maybe 5 GPM he's going to be using. If not, a screw together style coupler should work fine. Also very easy to find, but cost more.....
I've done a lot of hydraulic work too..... so has Rescue11. But I'll bite.... lets see what your guys say. Just be sure that you supply them with the correct info.
Old 03-24-2017, 08:08 PM
The Surplus center has an assortment of hydro connections ,hose
