Old 04-18-2017, 12:24 PM
Walmart is good at taking advantage of their customers. I doubt they will sell enough non ethanol fuel to keep a fresh supply in their bulk tank. 6-8 months from now the end user will have the same problems they had running E10.
If ethanol-free is readily available,,,it is possible that the station simply uses one tank,,
then they can have a pump labeled "10% ethanol max"
and also have a pump labeled "ethanol-free"
The buyer simply has a choice of how much to pay,,,
The single tank would be filled often,,,
Old 04-18-2017, 12:48 PM
The simple test would be to put a little from each pump into mason jars and then see if one seperates after a few months.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-18-2017, 01:14 PM
Even a single tank is usually around 12,000 gal minimum. Can be as large as 24,000 gal. When you think about how many cars, that may not sound like much..... but if they aren't choosing that grade, then it can take months to empty it. No, they don't have to fill it full, but they will put at least a transport load in, which is about 6,000 gal.
Old 04-18-2017, 04:40 PM
I run regular 87 octane but I use the snake oil (MMO) in all my gas with a good glunk of Star Tron. My pos fuel can lost the little top cap thingy so the can sits out on a wood pallet in my open chicken barn unsealed and I don't have any fuel issues. Maybe I'm just lucky.
The gas in my HD has been in there for about 2 to 3 years now and it started fine a few months ago. I run 93 octane & Star Tron in it.
I'm not for or against either I just never really had an issue yet. Maybe the glunk of Star Tron is doing its thing.
Old 04-18-2017, 05:06 PM
Merk Merk is offline
Most buyers will buy the cheaper gas....
Run what you want to run.....been running E10 gas close to 15 years with no fuel related issues.
Project Uncle Dick
Cub Cadet 70
Old 04-18-2017, 07:38 PM
I run the E10 (I guess, whatever the station on the way home/to work has cheapest) in my Cub Cadet too....never worried about it. However....I don't let the gas sit in the can for long- probably no longer than a month- before I either make sure I use it up somehow, wither it be mowing or dumping it in the pickup. Dad uses ethanol free gas in his boat so it doesn't destroy the inside of the engine.
Old 04-18-2017, 08:09 PM
It is for sale any where or can be , except in counties with big cities and their pollution levels must meet US EPA levels or loose fed funding for roads
KC has been close to loosing funding and would but the breeze blows away the smog mostly to forested areas where it settles
A QT has it south of KC
Old 04-24-2017, 07:35 PM
I drove by the new station today,,, and took a pic,,,
