Old 04-18-2017, 10:04 PM
john hall's Avatar
Good luck with the Cadet trimmer. Had a friend with one several years back--he was not impressed.
Me, dad, and a friend (who is a Stihl mechanic) tried real hard to resurrect a 2-3 year old Troybilt trimmer. I ordered a whole new carb (same model and brand) trying to get it to run right. Had obviously changed the usual--plug, fuel line, filter etc. We finally decided it had a crank seal going out. Being MTD you can pull up parts books--nothing on the engine was serviceable--just buy another "engine unit" for about $55. For $165 the entire trimmer could be replaced. Finally scrapped it and told the owner to get a new one--they went with battery power and couldn't be happier.
If I had to get a new trimmer, nothing but ECHO for this guy. Got a SRM3000--late 80's model in the garage--what a beast. Just last weekend my son used my FIL's SRM-200BE--its 35 years old an hadn't been cranked in a year. weed trimmers are like lawnmowers--you get what you pay for.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-19-2017, 07:17 AM
Sam Mac Sam Mac is online now
Originally Posted by mjsoldcub View Post
That fs90 you have Sam is that a four stroke?? It should be, of course it still requires modded gas, but if you ever have the plastics off it will have a rocker box to Dr and overhead valves...I have the same power head hanging from my ceiling, (actually a couple) looking for a few straight shafts .....That's a good piece of equipment...I wouldn't want to borrow it out either....
Stihl calls them 4mix engines
Yep the FS90 is the 4mix. It will take down a 1" tree like it's grass with the brush blade on it.
I'll get into the taco cutter today and see if it's worth my time. I'm not going to put any serious $$$ into it considering how cheap these thing are.
Old 04-19-2017, 09:03 AM
pardon my terrible spelling in that post.. i meant mixed gas, and overhead valves....yup, nice piece of equipment...mine starts on like a half of yank too....
Old 04-19-2017, 09:37 AM
Terry C's Avatar
Terry C Terry C is offline
I am a Echo guy also. Got an 80s 452vl saw still cuts like new one. Don't remember how old my trimmer is but at least 10yr
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 04-19-2017, 03:38 PM
It lives! Besides the rope it needed a carb kit and an oil change. The gear box looks like it got loose on the tube, PO had put a self taper sheet metal screw in it to keep it on the shaft but the screw hole in the tube had turned into a slot so the head could rotate a bit. His fix was blue painters masking tape, I'm not kidding blue masking tape. Needless to say the gear box came off, got disassembled, cleaned out and refilled with Mobil 1 grease. I drilled a new hole on the opposite side and tapped the tube for a 1/4-28 bolt. Runs decent but it's no Sthil. Local Cub Sthil dealer had the carb kit, rope and fuel line in stock. I'm into it for $40.42 plus my time.
Edit: Forgot to mention, these cheap things don't even have a clutch.
Old 04-19-2017, 04:03 PM
Glad you got it going Sam. I'm surprised it doesn't have a clutch, every cub trimmer I've had has had a clutch.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-19-2017, 04:58 PM
mortten mortten is offline
I would have at least used duct tape. The blue stuff comes off too easy. Glad its running.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 04-19-2017, 05:04 PM
$40.42....? Does that include the Chivas Regal?
Old 04-19-2017, 05:12 PM
Unfortunately no. Guess I should include that as shop supplies.
Old 04-19-2017, 06:24 PM
Sam I believe you mislabeled that on the invoice. It's called "consumables".............literally
