Old 05-02-2017, 07:42 AM
Ridingmowers1 Ridingmowers1 is offline
Try pulling the spark plug and ground it to the block and start the tractor and check to see if you have good spark
Old 05-02-2017, 08:35 AM
Originally Posted by Ian Cub Cadet 125 View Post
Thanks George I got it figured out and it was actually right on and at full spread it was .020 now next issue I think it could be my coil now I had a battery tender on it and my key was on but my coil was super hot to the touch is this normal? Also my resistance on my coil with key off is 2.0 ohms does this tell you guys anything? So close to having this cub right back to 1968
Ya it is normal to cook a coil by leaving the key on, and it gets hot.
You might get lucky and it still works, it is not good for the points either.
if you got spark @ the plug it might be ok.
Don't fret about leaving the key on, it has happened more times than ppl admit too.
To error is human.
luck!
Old 05-02-2017, 03:02 PM
jcsmith jcsmith is offline
X2 on what George said. If you have kids, take the key out when not in use.
Little fingers like turning things.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 05-02-2017, 08:33 PM
Welcome to OCC!
Old 05-02-2017, 09:20 PM
Ian Cub Cadet 125's Avatar
Ian Cub Cadet 125 Ian Cub Cadet 125 is offline
Ok thanks the key was on, on purpose for setting timing it was on a half hour tops. Its reading 2 ohms resistance what is typical for a k301 coil???
Old 05-03-2017, 12:58 AM
3.5 ohm coil is what they are supposed to have.
I'm not convinced you set the timing right.... The points should just crack open at the "S" mark. The gap at "full spread" is completely irrelevant. Don't even bother to measure it. It's that unimportant. Just make sure that they break contact at the "S" mark.
Don't leave the key on while setting the timing. Just turn it on when you need it. You don't even have to turn the key on. If you use a test light, just hook it up to the positive side of the battery, and touch the probe to the screw where the coil wire hooks to it. No need to fiddle with a multi-meter like in Matt G's post. That way is cumbersome.
At this point, I'm not sure what problem your trying to fix... Slow crank speed or what you think is an ignition issue.... checking the timing is good, but why are you concerned with a weak spark? One thing at a time. If you go trying to "fix" multiple things, you may just be wasting money. Lets figure out whether you actually have a cranking issue, or an ignition issue.
So...... does it crank?
Does it have spark?
Old 05-03-2017, 08:03 PM
Ok j-mech yes it cranks but too slowly so it either barely gets started or loses too much juice it wasnt sparking on "S" so that was on my list of things nows its all good and at full spread it is the correct .02.... I cleaned up my connections. My coil has 2 ohms of resistance. SO my only question i believe now is whether having 2 ohms of resistance could effect it firing up quicker (inconsistant spark or something) or if I should rebuild my starter? IMO but not 100% im not getting the cranking speed I need to help her turn over but Im not sure never played with a K301 before..... oh and yes it has spark
Old 05-03-2017, 08:11 PM
Let me put it this way.... My starter generatorator is cranking too slowly..
Old 05-03-2017, 11:51 PM
No, the low ohms won't keep it from running, but may affect performance. I'd say the coil is getting old and weak. You just posted a few days ago that it had 3 ohms, and now it's 2....?? Maybe that bout with leaving the key on got it. You can burn them up that way.... but only if they are on their way out usually.
I'm not sure you're understanding on the whole point gap thing.... but as long as you're sure the points are just opening at the right time, then I'll drop it.
Ok. So, how old is this battery?
Back to the original ideas. Make sure the wiring is good, solenoid is good.... if it is, then yep. Time to rebuild the S/G.
