Old 05-01-2017, 01:17 PM
Originally Posted by jrichards View Post
On the pulley hub there looks like there might be a pin? If you have ever removed an axle from a car, there is a pin that bends over the axle and the rotor. Is there something like that on this pulley and hub?
Are you talking about a cotter pin? That goes through a castellated nut and over the spindle? Nothing on a "car" bends over the "axle and the rotor" to hold an "axle" on a "car"..... If your not talking about a cotter pin, I have no idea what you are referencing.
No... this pulley only has set screws. Remove them, and use a puller like suggested. Might need some heat too. And not from a wimpy propane torch. From an acetylene torch. HOT, HOT, HOT!
Old 05-01-2017, 01:37 PM
Carefull with the HEAT, on the large cast iron pulley!!....
TOO MUCH in the center around the shaft and it will break on the outer edge!!
Old 05-01-2017, 02:20 PM
I'd be more worried that too much would super heat the shaft.... which would defeat the purpose.
When I said HOT, I was referring to the torch. Piddly little propane torch doesn't get hot enough. An acetylene torch gets HOT, HOT, HOT!
But you are correct. Don't overheat it..... fine line, that only experience can determine. But I doubt it comes off without some heat.
Old 05-05-2017, 11:28 AM
jrichards jrichards is offline
I have not had a chance to get much further with the disassembly as other projects have come up. I had a thought though that I wanted to bounce off of everyone. The tiller has a plug screw at the top of the gear box. You can unscrew it and see inside (though you can't see much). Would it be worth a shot to try and put some oil or lubricant into the gear box? Could the gears or chains be seized up because of rust and just not turning?
Old 05-05-2017, 12:23 PM
That I can ever recall, the 1A didn't roll out of the factory with a "plug screw". Either what you see is not what you think it is, or someone has added a lube hole.
If it is a plug to get to the chain, then I don't suppose it will hurt anything. Maybe you should post a pic of it just to be sure it is what you think it is.
Old 05-05-2017, 01:01 PM
This plug is at the top of the gear box
Old 05-05-2017, 01:06 PM
That was added. NOT factory.
Dump some oil in it. See what happens. Not gonna hurt it.
Old 05-05-2017, 01:07 PM
What kind of oil would you suggest?
Old 05-05-2017, 01:10 PM
If it is froze up from rust, I'd suggest Kroil, or MMO.
Old 05-05-2017, 01:17 PM
So just spray it in and let it sit? Or would it be worth to actually get some oil and poor it in?
