Old 02-02-2022, 12:33 PM
We tried to replace a 40+ year old door, but, because of it being brick inside and out, no carpenter would even consider the install,, even at $4,000.
SO, I removed the door, spent two days taking off the previous coats of "house paint" and repainted it.
The wife picked a color,, I decided to try to mix some tractor paints that I had in the shop, and paint it with that, mostly as a primer.
Well, I ended up almost perfectly matching the color the wife had chose.
50% AC Orange
35% IH Red
15% JD Green
AND hardener,, I buy hardener from Tractor Supply (the paint, also)
That door was painted at about 2PM,, and it was dry enough to install by 5PM.
I considered the paint fully hard within 48 hours,, it was probably less.
Old 02-04-2022, 07:08 PM
Wntsom4 Wntsom4 is offline
I just painted mine using CASE primer and paint
Was 8 to 1 ratio. 8 parts paint 1 part reducer and 1 part hardner
The more hardner the faster the paint will dry.
Took me close to 2 quarts white and 2 quarts yellow to do the full tractor and QA-42A. Have the deck still to do this summer
I recommend of you can get a rattle can of each from case for touch ups
