No, 2K primer is different from epoxy primer.
Epoxy primer is designed to etch into the metal so it gets a good bite, some 2k primer is approved to go over bare metal and will usually be marked DTM for direct to metal.
yeah i shouldve been more clear in what i meant...epoxy primer and most 2k or 2 part primers ive ever used required a hardener or catalyst... there is a difference in the base resins, Jon is right, i dont remember what is what, and Tim knows what hes doing....epoxy will be the best sealer rust inhibitor, and the 2k will fill small voids etc....
just used to calling a 2 part a 2k... i even used an epoxy primer from germany that came in an aerosol can along time ago..had to punch a button on the bottom and shake for said minutes and no good after like 12hrs or something like that.... anyways good luck with it |
