Old 05-23-2017, 07:26 PM
ambrola's Avatar
ambrola ambrola is offline
Great job on a nice red Cub. Looks like you have all the skills to get it all done.
Old 05-23-2017, 08:05 PM
Looks like you pretty much did a great job doing the basics to have a good running tractor!
Up to 534 and counting...
Old 05-23-2017, 08:22 PM
PaulS's Avatar
PaulS PaulS is offline
Great work!!
Old 05-23-2017, 08:48 PM
Dirty Steve's Avatar
Great job!
Old 05-23-2017, 09:14 PM
DieselDoctor's Avatar
Great job! you have a nice pair of Cubs there. Looks like a good start to collecting the entire 82 series!
Old 05-23-2017, 09:35 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Nice save!
Queen Of The Quietlines!
Old 05-23-2017, 11:42 PM
Good save,
I'd check the blower housing to be certain there isn't debris inside.
Also I see you painted over the vent, and the pump fins.
Old 05-24-2017, 12:07 AM
johncub7172's Avatar
Thumbs up
looked to have been sitting a good while. Sheet steel looks straight, and tractor seemed mostly complete. I would have never guessed a stuck brake puck. Wonder how many thought it was a bad transmission.
Nice pick up!
Old 05-24-2017, 12:29 AM
I agree with Todd (zippy1), you really need to clean the paint off the vent on the rear. I also don't like that you painted the hydro. Paint is an insulator to heat. Hydro's were left unpainted originally for heat reasons. Will it overheat.... probably not. Will it run hotter, yes it will. On your next machine, don't paint it.
Nice work on the tractor!
If you really only picked it up "the other week" you work fast!
Stuck brake puck isn't all that uncommon. Too bad you tore it down so far to get it unstuck. It's not all bad. Now you have new gaskets.
Old 05-24-2017, 10:55 AM
walkertxr walkertxr is offline
Roger on the vent and hydro. Its just rustolem sunrise red so nothing a little brake clean can't fix. Yeah three weeks total, really loved working on it. Water had also got into the carb pretty gummed up. I found a place here in Kansas, outdoor power deals, that sells replacement carbs for 30 bucks. It was worked great right out of the box other than the choke lever being different. When the engine was out I took all the tins off. That critter had filled inside there too. Maybe down the road it will get a proper paint job but for now its already out at my brothers farm for mower duty. His 1440 is jealous.
