Old 05-27-2017, 12:57 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
More than likely one of them was dry when you put it up and one or more of the bearings pitted from the presence of moisture.. could be in the spindles or the tension idler.. my 374 had a bit of noise several years ago but a set of bearings and an idler made it quiet and smooth as can be.. My local car quest had the bearings in stock... all 6 of them were less than $40.. they use a common 6205 bearing and are really simple to replace.
Sam has some good links and tips on the 374 deck.. He posted a link earlier in this thread
Jay
Proud owner of the following:
Old 05-31-2017, 10:00 PM
pvolner pvolner is offline
I think I am going to to do a full overhaul on this deck while I got it apart. I have a 50 inch deck from a 782. What all do I have to change to put the 50 incher on?
Old 05-31-2017, 11:28 PM
Terry C's Avatar
Terry C Terry C is offline
Too much to mess with. Need a mule drive from a super that had a 50. Maybe even a different PTO.
Just replace the bearings in the Haban and mow the rest of the year. It's not a bad job. Restore it in the winter.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-01-2017, 04:46 AM
Terry, the GT's and SGT's use the same undercarraige for the 50" deck. They just use a different bolt position on the mule. A 2072 used the same PTO as a 782.
Just mount it. Only difference is noted above. That, and you will need a longer belt. The operators manual for the 50" deck tells how to set it up. You can find it here, page 15:
http://www.onlycubcadets.net/forum/s...ead.php?t=4702
Old 06-01-2017, 09:17 PM
dag1450 dag1450 is offline
Just to clarify....u have a 50" deck. But u will need the under carriage for that 50" deck. The 60" undercarriage won't work with the 50".
