Old 06-18-2017, 05:36 PM
Dirty Steve's Avatar
All's well that ends well!! Good work!!
Old 06-19-2017, 04:01 PM
The different holes for the spring position on the governor arm change the sensitivity. You really should see where Cub suggests they are set. Different applications have different levels of sensitivity. For example, if you set the sensitivity as you would for a generator up on your tractor, you're going to find that the governor works too much. It will jump RPM at the slightest load. You don't want that. You want a nice smooth transition from non load to load. Not a quick "snap". You can set it more sensitive than the Cub manual states, but only by maybe 1 hole. Just depends on what you're doing with it.
Overall, glad you got it running the speed it should be!
Old 06-19-2017, 04:45 PM
jimbob200521's Avatar
I wish the two motors I swapped had the same gov arms, would have been easier to compare the two. The original arm on the 2284 had the gov arm with 6 holes as opposed to the 4 on the motor we swapped (newer engine, go figure). I actually ended up using hole three in the pic below as opposed to where it is when I took the pic. When I mowed over the weekend, she seemed smooth in rpm changes whether from thick grass, climbing hills, or whatever else. I get what you're saying about sensitivity setting and not wanting the rpm's to "snap" around like that.
-Ryan
