Old 06-14-2017, 11:26 PM
nitsuj nitsuj is offline
Originally Posted by Dart1917 View Post
Just crack the 2 bolts loose but leave them snug enough to hold the bracket in place. Then with the tractor supported off the ground so the wheels can turn and the tractor running tap the bracket up or down to adjust. The bolt holes are slotted to allow movement up and down. Use a punch and hammer to tap on the bracket until the wheels stop turning. Shut the tractor off, tighten the bolts and restart the tractor to test ( sometimes the adjustment moves a little when you tighten the bolts). If needed, repeat adjustment. Good luck.
Oh. Ok, the mounts are slotted. I'll have to take another look tomorrow. I'm done in the garage for the night.
Old 06-15-2017, 07:15 AM
Loosen #22 + 24 then you can move the bracket up or down to adjust as needed.
Old 06-18-2017, 02:10 AM
Got it! Thanks all. Just as indicated, loosened the bolts and moved the bracket and it's all good. Made all the difference in the world! Functions as it should.
So here's a related question... The bracket is pretty much at the end of it's range of adjustment. So at some point down the road, if the problem comes back, and I have no more adjustment, what will my option be? Or will it likely never need adjusted again?
Old 06-18-2017, 09:15 AM
bugeye bugeye is offline
As an added suggestion. When you remove the driveshaft to replace the hydro fan, disassemble the CV joints and clean/re-grease. Replace the rubber boots if torn or questionable. The boots can be sealed to the shaft with a tie wrap. The shaft has a zerk. Clear the old grease.
We all love pictures.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 06-18-2017, 12:47 PM
Well then, pictures you shall have! I'll snap some next time I'm wrenching on it. I don't believe my driveshaft has rubber boots, so I'm guessing they rotted off and weren't replaced by the previous owner. I'll add them to my order.
