Old 06-24-2017, 09:40 PM
Jdgreen Jdgreen is offline
Thank you for all your input everyone I just went out and looked at it and it has an the aluminum upper grill frame and the wires do go through the firewall. Which from what you're saying would indicate that it's a later one which would mean not pre production at all but late production
Old 06-24-2017, 10:14 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Early to mid production had cast iron lower grill frame and the exhaust protruded through the grill. Amp gauges varied cosmetically, too. Later production had one inch front spindles and cast aluminum rear axle tubes.
Queen Of The Quietlines!
Old 06-25-2017, 12:59 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
It's early because it has the long exhaust pipe with the hole in the grille. But that doesn't mean its pre production... that may be hard to prove with no tag.. You might ask the family if they have any paperwork or a bill of sale?
Jay
Proud owner of the following:
Old 06-25-2017, 01:21 AM
SS5150's Avatar
SS5150 SS5150 is offline
I was going to try to get that lot and split the pieces up. I wanted the 1200 and the IH cast weights, and friend wanted the snowplow.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 06-25-2017, 09:47 AM
finsruskw finsruskw is online now
1" front axles started at ser #632502 according to the parts book I have.
And the QL series started at ser #530001 and ran through #664996.
As others have stated, a good sales pitch story!!
Old 06-25-2017, 10:30 AM
Bob95065 Bob95065 is offline
Originally Posted by twoton View Post
Hmmm..., I thought it was the other way around.. I'm prolly wrong johncub7172, but I thought the short tip was on the late models, ....
I have a 1000 that was made in August if 1977 that I have known since it was new. I also have a 1450 that was made in January 1975. The 1000 has the short exhaust tip that does not protrude past the metal screen. The 1450 has the long tip that comes through a hole in the screen. The 1000 has the cast aluminum lower grill and the 1450 has the cast iron lower grill.
Old 06-25-2017, 05:06 PM
It has the lower cast front grill frame and it has the cast iron axle tubes so I will say its a early one from what most of you are saying. Would any of the casting numbers on the rear help determine anything?
Old 06-25-2017, 05:52 PM
Casting numbers won't help. Serial number on the engine would, if it's the original motor.... but seriously, who caresponded what year it is. It's really irrelevant.
Old 06-25-2017, 06:56 PM
IF, you are lucky, the engine tag will tell you the year the engine was built.
