Old 07-27-2017, 11:49 PM
Originally Posted by sorner View Post
Yup, pull it and remove the shrouds and look around. Save your knuckles. It's not terribly hard on the 2185 to get the engine off, but you might have trouble getting the exhaust apart to release the engine. I had two that I tore apart, both were rusted. The pipe was rusted and wouldn't come off the muffler inlet, and the bolts were rusted where the muffler is attached and the bolts broke off. New mufflers are pretty expensive for that. If that comes apart easily, the rest is a piece of cake.
That's why I have PB Blaster by the case in the shop. A couple days before planned extraction, spray down, and let er eat. Don't always work, but most times it's a success...
Old 07-28-2017, 03:59 PM
bluesman bluesman is offline
PB blaster......the tractor dudes best friend. I use a lot of it.
I will attempt to address my procrastination problem while you wait.
Old 07-28-2017, 11:13 PM
sorner's Avatar
sorner sorner is offline
I've actually just started using it recently. I was using Wd40 with bluetorch, but PB Blaster seems much better... and stinkier.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
