Thanks for the helpful comments so far everyone.
Since the tower is way out of specs I'll be ordering a coil today. I may just get a plug wire while I'm at it as well.
Buy American made Products!
Just check things as they are, and eliminate things one @ a time.
The coil might be bad, but make sure the points are making/braking as they should and not grounding out. Sometimes it's where the wire is connected to them, or on the cover or a bare place to the coil, or on the points themselves. When you are sure they are operating correctly, you might be surprised that the coil works even though it is out of spec's. It costs nothing to try. |
X2 what ol'George said.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
Well, inquiring minds want to know. Is it fixed?
Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction .
My K301 engine was running just fine today while mowing then all of a sudden it just shut off & would not start.
I did find a loose wire that broke off the 2nd terminal of the voltage regulator after I wiggled it so replaced the connector. All other wiring looks fine throughout the system. No Spark at plug No Spark at points so I'm thinking the coil or condenser or both went out because it was running fine right before it quit. |
Ok So I disconnected the + side of the coil wire that runs towards the generator then ran a jumper wire from the + side of the coil to the + side of the battery & she fired right up & ran fine.So now I need to find out where that wire from the + side of the coil goes it runs along the frame & I can only assume back to the ignition switch? Am I right on that?
Appreciate you're help! |
