Old 07-21-2017, 10:44 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
This is depressing, we are already talking about leaves. GROSS. Don't even mention the 4 letter S word yet.
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 07-22-2017, 06:50 AM
john hall's Avatar
Like it or not, it will be here soon enough. I saw a Cotton Picker on CL this week, you don't see them advertised in the dead of winter--just saying......
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 07-22-2017, 07:31 AM
mike melillo mike melillo is offline
Used to use a tow behind vacuum but with 5 acres it fills too quickly. This set up is what I use now and it's really awesome.
Mike
Old 07-22-2017, 11:39 AM
I use my fan assisted bagger most of the time in the fall and it works awesome.
If I gotta blow em then it's the Steiner or the trusty old RedMax backpack blower.
Old 07-22-2017, 02:06 PM
dodge trucker dodge trucker is offline
I hate leaf season. rake and rake and rake, have had a few sweepers, have tried bagging, did have a trac vac for a while, mower I had it with just kinda plowed the leaves instead of going over them.. 0nce it did finally decide to go over the pile it plowed itself into the deck would clog....
rake em into the ditch then go get some gas and a match, and watch.
Old 07-22-2017, 10:26 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Talking
I usually take the burning approach for larger piles but if you can work just alittle at a time I have been known to blow them into the nieghbors yard
Old 07-23-2017, 09:44 AM
bugeye bugeye is offline
I use a TracVac. Many trees(160+) on 4.5 acres. I only pick up when the leaves are dry. Many long days of effort as if the leaves are permitted to accumulate too deep, then I'm plowing, unclogging the mower deck and hose. The leaves are abrasive cleaning the underside of the deck.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 07-25-2017, 07:26 AM
jd8181 jd8181 is offline
Thanks guys. I ended up picking up this vac over the weekend. Starts right up, but has a slight miss at full throttle. Runs fine at full throttle if the chock is about 3/4 on. The guy said the gas is probably a few years old. So I ran it out and filled it up with some 91 octane and sea foam. Also replaced the spark plug and dropped the carb bowl and cleaned it and the main yet (there was all kinds of crap in the bowl). I'm going to run it for a little bit and see if it clears out. If not I'll probably take the whole carb off and redo it (motor is a Briggs intek 900.
I also need to figure out how to take the plastic grass flap off the mower deck so I can figure out how to mount the boot for the vac.
Old 07-26-2017, 06:48 AM
Be sure to pick up the sticks or avoid them as anything larger than the diameter of your thumb will jam in the hose and cause a clog. I hate shutting everything down to remove the flex hose, shake it, reach in to pull out leaves, sticks, then reassemble to start sucking leaves again. But, without the TracVac, the leaves would be impossible for me.
Old 07-26-2017, 07:29 AM
Thanks for the heads up. I was surprised that the hose is smooth on the inside. That will probably help it from clogging up some. I'm ready to figure out how to mount the boot and give it a try.
