I had a similar power loss under load with my Kohler Command. I blew in the fuel line from the filter back to the tank. It temporarily helped, but the power loss shortly returned. I then pulled the fuel tank. The valves on the bottom of the tank were packed with debris. Then cleaned tank, valves and replaced fuel line, filter. Carburetor cleaned. No more power loss issues.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580 |
make sure the fuel tank is venting properly. check the vent on the fuel cap
You guys who have these running issues where the tractor dies after so long have GOT to start figuring out whether you are losing fuel of spark. It's a quick test and MUST be carried out immediately after the machine dies. Figure out which system needs fixing and then we can proceed. You can replace all the parts you want, but until you know whether it is fuel or spark related you are just guessing. A motor only needs 3 things to run: Fuel, air and fire. Most generally air is fine, but I've seen plugged air filters that were so bad engines wouldn't run before. |
