Old 08-05-2017, 08:01 PM
Workinprogress Workinprogress is offline
After a little welding I was able to get a test run of the plow. While I didn't actually plow a garden I used the plow to help dig a ditch for a drainage pipe.
Here is the sleeve to 3 pt adaptor I made. Material for toplink attachment point is a little thinner than I would like. This was prebent scrap material from an old trailer. Was easy to install and I didn't need to bend anything. If it bends I will just add some more material.
Been raining most of the day so ground is a little wet but the plow was able to cut in. This is the same area i broke up with the subsoiler ripper.
Once the ground drys some I think I should be able to make a nice ditch for drainage pipe with the plow. Will have to make a pass then move the extra material to keep the tractor flat.
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 08-05-2017, 10:26 PM
You won't bend your adapter. It's plenty heavy. You're not pulling a 3 bottom 16" plow.
On another note, this is a plow, not a ditcher. You can only go so deep. I don't know how deep you need to go for your drainage pipe, but if you get a 8" deep hole with it, that's all you're going to get. You can't just keep moving dirt and plowing deeper. It can only move dirt so deep, then the wing on the moldboard will hit the ground. Even if you make it two passes wide, then go deeper on the on the left side, it will only go so deep. Plus, looks like you are running it through a lot of gravel. That will wear, or break the point right off of the plow. Better just use it for plowing, not ditching in gravel or you won't have a good plow left. Rent a trencher, or use the subsoiler point and a shovel.... or a blade.
