Old 03-05-2018, 05:58 PM
samckitt samckitt is offline
What driveshaft should I look for putting this Command 18 in the 1872?
________________________
Scot
Old 03-05-2018, 06:14 PM
sorner's Avatar
sorner sorner is offline
Is this what the engine mount plate is for that I just sent out this morning?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 03-05-2018, 06:57 PM
If it was shipped to williamsburg, VA, then yep it was me. LOL
Scot
Old 03-05-2018, 07:03 PM
sorner's Avatar
Yup it was.
I used part of a cut off 2185 driveshaft and the original 82 drive shaft and slid the 82 shaft into the 2185 shaft, so the rear was the original connection and the 2185 end went to the engine. That was on a 682 though, the 1872 would be longer and I’m not sure if that’s work. I don’t have that tractor anymore.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 03-06-2018, 01:08 PM
I take it the 2185 is hollow, and happens to be the same ID as the OD of the 682/1872?
Scot
Old 03-06-2018, 01:18 PM
It is hollow, but I do not believe the solid shaft is a tight fit to the hollow one. I would get a hold of Jeff in PA for some help.
Old 03-06-2018, 03:43 PM
Jon actually the 2000 series shaft is a nice snug fit to the 5/8" shaft used on most older Cubs. That's what I did on my 149 at the engine end. The 149 drive cup was shot as was the end of the drive shaft. Once I got the length as I wanted it I marked it, pulled it out of the tractor, drilled it and put a 1/4" spirol pin in it. Then I reinstalled it.
Old 03-06-2018, 04:31 PM
I never tried it. I knew someone had, but couldn't remember any details. I had it in my mind that it was close, but not a tight fit. Good to know.
Old 03-06-2018, 05:57 PM
ironman's Avatar
ironman ironman is offline
Sam, have you concocted any way to use this ides at the other end of the driveshaft to eliminate the rag joint? In other words is there any kind of coupler that can go on the hydro shaft that will bolt up to the barrel housing?
Old 03-06-2018, 08:28 PM
Jeff in PA makes the pump adapters that allow you to use the 2000 series or the CV style drive shafts. 1st pic is the type needed for something like a 782 with a 5/8" round shaft with the spirol pin, the 2nd is for the Supers or Cyclops that have the 5/8" nine spline shafts.
