Old 08-18-2017, 09:49 PM
taylorjm taylorjm is offline
This is what the road looks like.
Old 08-19-2017, 12:00 AM
Don't look to bad to me.
Up at our cabin, the driveway going in was hard packed, and couldn't do much with the push blade. So used a one section from a spring tooth drag. Back and forth with the drag adjusted pretty aggressively, loosened the soil up easily.
Then finished up the leveling with the push blade. That's what we had, so that's what we used...
Old 08-19-2017, 02:11 AM
DieselDoctor's Avatar
TaylorJM - watch Ebay for that box blade from Impact Implements like I posted pics of. They frequently list one as a no reserve 99 cents starting amount auction. That's how I got mine for less than $300. I'm very pleased with it and they are built very rugged. If you would like better pictures or close-ups of anything, shoot me a PM with your direct e-mail address and I'll send what ever you'd like to see. Stan
Old 08-19-2017, 07:04 AM
drcjv's Avatar
drcjv drcjv is offline
I have a 400' stone drive and large stone area between my out buildings. It is not cheap but what I bought works like a charm and I pull it with my supers with no problem. I bought a 48" DR power grader. One of the best tools I ever bought. Takes out pot holes beautifully. Depth level is adjustable from your seat. I think they now make a manual adjusted model that is less expensive. It does not matter how hard packed it is it will pull it up. Manual $600 power $900 both with use for a year if not happy send back. I had a box blade for my bigger tractor this works better. I added a few cinder blocks for weight. I know it might look small but it works great. Over the years I have had multiple people stop and ask how I was able to get the driveway so smooth. Had offers to pay to come do their drives.
http://www.drpower.com/power-equipment/power-graders/
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 08-19-2017, 12:59 PM
Thanks for the tips. I'll keep an eye out on the Impact Implements one. I've seen the dr grader models and couldn't figure out why they were so much more and worked better. Adjusting the height wouldn't be an issue with the 3 pt hitch I can raise the spikes, but I'll look again. I see them used once in awhile.
Old 08-20-2017, 06:17 PM
So, to add to the original question, a stupid follow up. When you use the 3pt hitch for something like a grader, do you have to remove the mower deck? The tractor is an hour away, so I can't look, and I can't remember if the deck and hitch both go up/down, or if they are reversed.
Old 08-20-2017, 06:33 PM
Better to remove the deck on a 2182. Could probably screw the adjustment knob all the way up and hold it, but if you have a 60" Haban on it, it's too hard on the subframe to carry it. Plus, it won't lift very high, and who wants the headache of readjusting it all the time. Deck and 3pt are the same lift.
Old 08-20-2017, 08:19 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Not on my 1864
1- 1200 in pieces
1- 1864 in pieces
Old 08-20-2017, 08:45 PM
Yeah, that's what I figured. I've only taken the deck off once and put it back on and it was a pain in the butt, but I haven't figured out the best way yet. I know I took out too many parts last time. I guess I'll get to practice!
