Old 08-24-2017, 12:49 PM
bfowler88's Avatar
bfowler88 bfowler88 is offline
That would be weird....a red one puttering and shaking like a yellow one...
Might be sorta cool. I'd like to see it.
Are you offering to donate an engine?
1971 IHC Cub cadet 106
1982 IHC Cub Cadet 682 (looking for engine)
Old 08-24-2017, 12:54 PM
It would be just like a 1282 which was basically a 682 with a 12hp single.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-24-2017, 02:58 PM
Or a 680, 1050, 1204, 1210, 1211.
To the OP:
Finding a motor isn't near as hard to do as finding the engine mount will be.
Old 08-24-2017, 09:15 PM
Naw, only got one, and it's still making my 147 move.
Good luck!
Old 08-25-2017, 07:06 AM
dodge trucker dodge trucker is offline
I wish I could find a mag 18 horizontal.... and when I do people think they must be made of gold.
Old 08-27-2017, 08:56 PM
bfowler88's Avatar
Had some time to get the old engine out this evening and do some cleaning on the 682. Attached are some pictures. Look at the hole in the side of the engine. I'm impressed at how heavily built this tractor is as well as the 106. I used the 106 earlier to move my 1800lb trailer earlier and it seemed to do it well. Another question, my 682 serial number is a 707 etc... so i know it was built after cub cadet was bought by mtd. I read that alot of them were built with left over IH parts to use up the inventory and i'm wondering about parts used on mine. I Have a red rear axle so i believe it is the IH axle, it also says international on the hood and has the decal behind the seat. ON the instrument tower it just says cub cadet without the international emblem which ive heard some have. I also do not have the IH logo on the grill( could have fallen off i suppose) SO basically after all this i'm wondering if mine was a "frankenstein model" where IH and MTD made parts were used and if so is the quality sub par to the 100% IH built 682's . Thanks in advance!
Old 08-27-2017, 09:05 PM
john hall's Avatar
Does your serial tag say International Harvester? yeah, I've seen some that appear to be built from whatever inventory was on hand. If you didn't know, stick a magnet to the actual rear end casting (not the cover plate on the back) to see if you have an aluminum or cast iron rear. Not saying one is better or worse, just that there are 2 possibilities.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-27-2017, 09:16 PM
bfowler88's Avatar
serial plate says cub cadet and i will try the magnet trick.Thanks
Old 08-27-2017, 09:22 PM
Red rear axle: cast iron, built by IH
Black rear axle: aluminum built by MTD
With the exception of the serial tag, and lack of emblems, your 682 is an IH machine.
Old 08-27-2017, 09:42 PM
sorner's Avatar
sorner sorner is offline
Aluminum vs Cast Iron... go!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
