Old 08-30-2017, 08:21 AM
dale c. dale c. is offline
have you checked the point gap / timing , cleaned the points etc.?
Old 08-30-2017, 09:30 PM
three4rd three4rd is offline
Bought new points today, along with condenser and coil - did not get everything put back on since I'm also cleaning the carb. But...since you brought it up (and I was going to ask anyway)...I'm concerned about having the points gap at exactly the right place in the timing. When I turn the engine by hand, I can see where at some point the bar comes out as far is it's going to - and then I understand about gapping it to .020 and locking it in place. I did that. But, what confuses me is that continued turning of the engine seem to produce no change in the position of the bar until you really turn it a good amount. So...how do I know if I have the points gap open at its widest at the correct place in engine rotation? Should it be just as soon as the bar pushes out its farthest? I don't have a timing light and so need to set this as best I can. Also, I've read about using the sight-hole...have no idea where this is (?)
Old 08-30-2017, 09:32 PM
Read this, and do it.
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Old 08-30-2017, 11:37 PM
I did read all that - great reference - but as I said in another thread, I can't find the marks - too much rust and dirt on the flywheel I guess.
Old 08-30-2017, 11:49 PM
Get a small wire brush that goes on the end of a drill. Stick it though the hole, turn the morning by hand and polish the flywheel. You can start by removing the exhaust plug and watching for the exhaust valve to open. , then roll the motor back just a bit. That will get you close to the mark. One you find and clean it, you will have to turn the engine one revolution.
Old 09-01-2017, 05:57 PM
Oak Oak is online now
I'm going to throw this out there.
Give a man a fish, and you feed him for a day. Teach a man to fish, and you feed him for a lifetime.
Do you have basic hand tools to rebuild an engine?
Do you have a camera to take a ton of pics?
Download the free Kohler manual and read all that you can.
Tear the engine down taking lots of pics for a reference and for posting questions here.
Find a good machine shop in your area that can bore it and turn the crank.
When they tell you what size pistons and rods to get, order from this guy.
http://www.ebay.com/itm/Kohler-K301-...OE7GHmbYMBso1Q
You'll have $100 in parts and probably $100 to $200 at the machine shop.
After work in the evenings, crack you a cold beer or pour you a hot cup of coffee and start the reassembly.
These engines are simple and fun to work on. If you're not sure, take some pics and ask questions on here. You are working on a 35 year old lawn mower and not the space shuttle. If you "F" up you're out $300 and starting from scratch. You are in the land of Cub Cadet's and shouldn't have an issue if you need another motor if this one gernades.
Old 09-01-2017, 06:46 PM
Oak...thanks. I really appreciate that but I don't think I'm quite up to it. For one thing, the next 2 months are extremely busy for me so I don't really have the time to devote to it, which would undoubtedly take me 10-20 times longer than someone who has the experience working on these. Believe me, I do take lots of pics and notes when I do virtually anything on the Cub, but I think I'll get a rebuilt short block and leave the work to my brother's service station. IF it was in the middle of winter and I had hardly anything else to do, I'd perhaps be more willing to pursue what you suggested. I've already spent several nearly full days over the past week or so and am right where I started, and yet have spent the money for a new plug, points, condenser, and coil. None of those are at the heart of the problem. I've always taken great satisfaction out of being able to successfully complete jobs on the Cub over the years, but this one is just a bit too much I'm afraid. Still..you have tempted me
Old 09-01-2017, 09:49 PM
three, no problem, I understand. What I'm saying is, don't be intimidated by rebuilding one of these. If your going to spend $800 on a short block and then pay someone else $200 + to put it together you can probably by another machine in your neck of the woods.
Old 09-01-2017, 10:38 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Build a man a fire he's warm for a day, light a man on fire and he's warm for the rest of his life.
1- 1200 in pieces
1- 1864 in pieces
Old 09-02-2017, 01:04 AM
Well at least you admit it. And aren't like some who take things apart then leave it lay around, then give up, and ends up being a pile of junk. Parts...
BUT, sometime you'll need to face your fears.
