Go Back   Only Cub Cadets > Off Topic > Suggestion box
Old 09-16-2017, 05:19 PM
Well, there has to be some order or format to it. Some one will get on there and leave a dissertation and/or a lengthy description.
Something like this..... This is just an example and NOT anything factual. The table can change to add more information.
Old 09-16-2017, 06:41 PM
I was hoping to avoid having one person handling it, i think members would be more likely to post the info themselves then take the time to pm me but it is your forum so we will do it your way. I will PM you later.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-16-2017, 06:47 PM
It was only a Suggestion.
Old 09-17-2017, 08:33 AM
john hall's Avatar
I don't know how hard this will be to do, but I like the idea, if its not going to cause someone a bunch of work. A concern of mine would be accuracy. What if whomever is loading info types in one # wrong, then we have an issue. I certainly can see where this whole idea would come in handy. I'm like most, I search and find my own aftermarket, but sometimes that can be slow go. If this gets off the ground, I'll try to support by supplying part #'s and sources to whomever is making the list and checking it twice.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-17-2017, 12:28 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I found this thread in the parts section. I was looking for cyclops wheel seals. I didn't find it there but I'm going to post that in another post. Maybe just sticky this thread and add to it or create a new one and sticky that.
http://www.onlycubcadets.net/forum/s...ad.php?t=36314
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-17-2017, 06:04 PM
I have created a "Sub Section" to the Parts Source Section for those that want to post Cross Reference part numbers.
We will see how it goes. If it turns out OK...then fine. If it turns out to be a massive problem, then I will delete it.
ENJOY.
Old 09-17-2017, 06:25 PM
Shrewcub's Avatar
Thanks Roland!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 09-17-2017, 08:57 PM
Bamafan Bamafan is offline
Inactive Member
ENJOY.
Thanks Roland, I think if members do their research before posting it will be a big help.
[B]Larry[/B]
Old 09-27-2017, 09:08 AM
OldSkull's Avatar
OldSkull OldSkull is offline
I take any suggestion to keep my fleet in mechanical order, this doesn't mean there is not a better suggestion or more up to date one out there, it is what it is! Good or bad as long someone take the time to share what he have found to help fellows here we should welcome his efforts!
Gilles.
1963 100 (red)/in storage
