Old 10-15-2017, 07:46 PM
lOOKS GOOD FROM HERE, BUT TOASTY
Old 10-15-2017, 07:54 PM
Check it out Jon, that’s an old Crown RR.
Ha! So it is!
Old 10-15-2017, 10:45 PM
CubDieselFan's Avatar
Tell me you didn't pick it up by the steering column.....
I am afraid we did. I did not pay for it till we had t on my trailer. I got it for what less than what the deck is worth. We did a test lift and nothing bent so the column is pretty sturdy.
Old 10-15-2017, 11:18 PM
No it isn't. I've seen guys do that time and again.... they all broke the column. I'd be shocked if you didn't. It's nothing more than a piece of exhaust pipe, and that tractor with the deck weighs in at nearly 1000#. I'm sure you broke/bent it. Don't load them like that. It would have been better to pick it up from under the deck than from the column. Or just push it, winch it..... ANYTHING other than lift them by the column.
Old 10-15-2017, 11:22 PM
Be shocked, it is not broken.
Old 10-15-2017, 11:24 PM
Not that you see as of yet......
I bought a tractor one time that had been loaded that way in the past. Much smaller tractor.... it was bent. It still worked, but it was bent.
Old 10-15-2017, 11:28 PM
We did not pick it up by the steering column. We picked it up by the frame of the dash. Sounds like you think we picked it up the steering column itself. I would never do that. I thought it would bent the framework but it did not.
Old 10-15-2017, 11:31 PM
Yes, I said steering column, not dash... then you said yes.
I still wouldn't have done that. Much better ways to load a dead machine. I try not to tear things up, even if they are for parts. A come along takes time, but it works just fine.
Old 10-15-2017, 11:33 PM
You were not there. That was the best way. Worked great.
Old 10-15-2017, 11:42 PM
No, I obviously wasn't, and it's not my machine. You can do whatever you want with your stuff. I'm just trying to tell you what not to do. If you choose to listen or not, that's your deal. I don't care if you break it, as long as you don't try to sell me (or others) broken parts off of it..... Or come back complaining that you broke something loading it.
Hope you can make it run, or part it out, whichever you choose. You got a good deal.
