Old 10-24-2017, 03:07 PM
sorner's Avatar
sorner sorner is offline
My guess is that Ryan wants to use a spreader something like this one.
I would get a piece of steel plate, use the existing hitch as a template to drill the 5 bolt holes then weld a receiver tube to it. You can get a receiver tube at any decent RV supply store or from Northern Tool.
Right after I hit "Submit Reply" and walked away from my computer that popped into my head of what he was wanting to do.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 10-24-2017, 04:38 PM
jimbob200521's Avatar
That's what I've got in mind Sam, spot on. Every year since I've done snow removal I've made one improvement per season to my snow operation. First year, I used shovels and a walk behind snow blower. I decided that had to end really quick, especially with how much I have to do at any hour of the day. Next year, cub with a blade. Next year after that, cab. Year after that (last year), somewhat insulated cab and some "fancy" wiring. This year, I want to eliminate getting out to spread salt. The goal is a one pass operation
-Ryan
Old 10-24-2017, 10:37 PM
I'd just change the salt spreader to mount on the existing hitch. The Reese hitch thing on it is likely bolted on. If you had 3pt this would be easy.... just mount it to the 3pt.
Old 10-24-2017, 11:02 PM
mortten mortten is offline
Wash that tractor good when you're done. Salt kills.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 10-24-2017, 11:05 PM
Yes!
Like every time you use it..... afterwords, wash it.
john hall's Avatar
For next season move to the South! Snow always melts in 2-3 days. If it snows,we declare a holiday and eat milk sandwiches. I probably play in the snow as much/more now than I ever have. Hey, somebody has to teach them youngins where all the good spots to sled are.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-25-2017, 06:54 AM
sbauerz28's Avatar
I built my own that ties into the rear axle tubes. I got the receiver from Tractor Supply. The only reason it's bolted on is because I had the hitch on my 1450.
Old 10-25-2017, 06:59 AM
Just my 2 cents, considering how bad the Cyclops tractors rust and rot I'm not sure putting a salt spreader on one is a good idea.
Old 10-26-2017, 12:23 PM
CNeubauer CNeubauer is offline
Here is the one I built for my 1872, I made one for my 2182 that bolts on in place of the regular hitch but this one is quite a bit stronger.
I have a picture of the one on my 2182 too, it's lower and better for lawn implements, the one on the 1872 is higher and better for everything else. I've been pulling a 37' man bucket lift around with the 1872, sticker on the hitch says it has 275lbs of hitch weight and it's been no problem.
