Old 12-18-2017, 12:46 PM
Originally Posted by scarps68 View Post
Well life got in the way, but I was finally able to get out to the shed. Here's what I found. There is a heavy gauge wire going from the + battery to the solenoid. From the solenoid, heavy wire goes to starter while smaller gauge wire goes to the ignition. Another wire runs from the starter to the push button.
I ran jumper cables from the battery to the solenoid and the push button would turn the starter, but not enough power to turn the motor over.
So to me it sounds like the starter is fine, but the PO did some crazy wiring. Is there a way to simplify and fix the problem?
There was a service bulletin on adding the 2nd ground wire but I can't find it right now.
***Edit***
Master Lew has it here.
http://www.onlycubcadets.net/forum/s...ad.php?t=47908
Old 12-18-2017, 03:18 PM
jbrewer's Avatar
jbrewer jbrewer is offline
You could TEMPORARILY take that out of the circuit by bolting the two heavy wires that are connected to the extra solenoid together they trying to crank the engine. INSULATE it well before you try this, but it should tell you whether the extra solenoid is contributing to the problem. (this is IF the original solenoid is still in the circuit)
It probably wont matter , since I too am leaning towards it being a grounding issue that the DPO tried to fix with a kludge.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-18-2017, 10:54 PM
Unless I'm missing something.... the starter in the pic appears to have a stud on the bottom that the wires are connected to. *IF* that is the case.... the starter is not the original.
If what happened is what I think happened the OP was kind of frugal.
Sounds like the solenoid on the starter had a failure on the plate that energizes the starter. The pull in function of the solenoid still worked. To solve the issue and not buy a whole new starter, he simply installed a cheap solenoid to actuate the starter motor, while the original engaged the bendix. *IF* that is the case, and the original solenoid is still present, then remove what the PO added, run the wires correctly and replace the original solenoid, or the whole stater assembly.
The way you describe the system to be wired cannot be correct, or nothing would work. I don't think you correctly following the wires. It's that or you aren't explaining it correctly, as it would NEVER have worked wired that way.
Post a better pic of the starter if you need me to confirm how things are wired.
Old 12-28-2017, 08:28 AM
jbrewer's Avatar
If you're still at this, I'd suggest removing the added solenoid and associated wiring and getting the tractor back to original configuration.
Once it's back to the way it was built, see if it work and diagnose it, and repair it the right way.
I work on a fair amount of old (tube type) electronics , and I approach things the same way. Removing the "improvements" that some Dreaded Previous Owner installed often simplifies the repair process and sometimes removes the fault altogether.
Keep us posted!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 01-02-2018, 09:29 PM
TheSaturnV's Avatar
Has this tractor ever started for you since you purchased it from the PO?
As mentioned, some well-lit and focused shots of the wiring, starter and anything else that looks butchered would be of help.
Old 03-01-2018, 09:29 PM
scarps68's Avatar
scarps68 scarps68 is offline
What are the recommended gauge wires for the heavy wire from battery to starter and smaller wire from the starter to switch? TIA
Don
882D
50" Deck Mower
54" Snow Dozer Blade
Agri-Fab Lawn Sweep
Old 03-01-2018, 10:17 PM
6 Ga is probably heavy enough. But you can go 4. Looked like the cable in the pics you have is the right size. Match it up.
Old 03-02-2018, 06:34 AM
jbrewer's Avatar
As fat as you can make them and get them safely routed. Mr Ohm never sleeps and the cranking current is hundreds of amps. If a starting system is marginal, this is a place to look.
If you suspect iffy cables or cable terminations, put a jumper cable in parallel with the existing cable and see if things improve. If they do, you're on the right track, if not, search elsewhere.
Check the ground connection again!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 03-02-2018, 08:42 AM
scarps68's Avatar
I think it may be the wrong ignition switch and I also found issues with the starter. New parts were delivered yesterday. I ask about wiring because I’m debating just running new wire knowing it’s all new and the connections will be done correctly.
Don
882D
50" Deck Mower
Agri-Fab Lawn Sweep
Old 03-02-2018, 09:14 AM
4 solid months since you started this thread..... I figured you had it fixed by now.
How do you figure it's the wrong ignition switch?
