Old 10-30-2017, 02:44 PM
Did you just say you owe me a dolla?
Not really, I did dry fit it, and it fit.
Up to 534 and counting...
Old 10-30-2017, 03:03 PM
You took the bolts out of the rear, lined up the holes and it fit......?? I don't see it not hitting.
I just went out and looked at my 1100 and a 1710 that are next to each other. I just don't see it working. Besides.... if it does fit, why didn't they sell a blue million of them? Guys always want a sleeve hitch on an aluminum rear. I would have thought they would be as common as sleeve hitches are to find. Guys trading up and wanting to use the equipment they already have. Plus, if it fits, why is it listed to only fit a tractor with a Peerless rear? I researched this to the hilt before I built my own adapter.......
Old 10-30-2017, 03:23 PM
A 1606 is not a peerless. CAW!CAW!CAW!
I guess those folks at CCC made the decision to no longer to supprt the old attachments.
Old 10-30-2017, 05:07 PM
No, but a 1604 is, and they use the same parts look up. What's your point?
Old 10-30-2017, 05:22 PM
John, you should buy the one you posted, if it don't fit you can put it on the 1100 you have.
In the book it list the 1606 using that bracket.
Old 10-30-2017, 07:28 PM
cdlong's Avatar
cdlong cdlong is offline
Thanks for trying to help guys! No way this will fit my CCC 582. I don't haave bolts where the plate has holes.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 10-30-2017, 09:51 PM
I would in a minute if I thought it would fit an aluminum rear tractor!
I got the 1100 in a package deal. Someone put a Techumseh engine in it. The T motor had a PTO on it similar to a CC PTO and it had brackets welded to the frame and a bunch of crappy brackets running up to the dash tower. Dash tower was broken and the rear end didn't have mounting bolts holding it in. Fenders are beat up and the hood got tossed in the scrap pile as it was too beat up to salvage. Also, they had taken the original tires off and put old donut spare tires in their place, then welded them to the hub. I only took it because it came in the deal and there were a few good parts to salvage off of it. Not many...... but ones I wanted! I need to strip it the rest of the way down and sell the rear. Someone needs it more than I do!
I'd say the book that lists it fitting a 1606 is a print error. Not just because it fits my position..... but because that bracket is listed all over to fit the 1100,482, and 582 Special. The 1604 is the same tractor. It will fit a 1604.
