Tim.
Rivets carefully install with the right pressure for the material used are almost indestructible, just think about how many "G" a airplane can be submit without falling apart in flight! But like welding there is the good way and the wrong way to do it.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
Ok, well if you put a rivet every 2" like an airplane, it would hold even with cheap rivets, but who wants to drill all those holes!
![]() I'd use self tapping sheet metal screws before I drilled holes and put rivets in. But, that's my opinion..... |
I suggest pre-painted aluminum sheets for your skin.... such as the kind used on race car bodies. The aluminum are available in many different colors Pop rivets are easy... use a good step drill or a sharp twist bit. It'd be real nice in install the plexi-glass, polycarbonate or even tempered glass with some kind of molded H shape rubber if it could be had (I'm sure you can....just got to look around).
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
G....I was keeping that one for a later post with the tie-rap and the $6 HF tarp. Now you give the punch dam it!
A few people think it is too tall, did you get your measurement by sitting in the seat? I know that being 6'3" I tend to build things taller than normal....
64 Cub Cadet 100 Also have quite a few Non Cub Cadets in the Shed
Doubt the canvas matl would like getting wet.![]() In all seriousness, there are some pretty high tech adhesives nowadays, but they probably cost way more than a bunch of bolts/rivets/spot welds/tack welds. To the OP, nice looking job so far. Keep us posted on your progress. I'm sure whatever you box it in with will be just fine. Now I think a big ol' LED lightbar across the top and a flashing strobe on the top would be the icing on the cake!
Being a glass guy, my go to adhesive is Automotive Urethane. Its a structural adhesive and its fairly cheap. You could go with sheet metal on the solid areas and I would use 3/16 to 1/4" lexan on the windows. You could use the urethane and rivets to put the lexan on just like the sheet metal. Use a primerless urethane if you go that way. Feel free to PM me if you want more info.
Randy
2 original cub cadets ![]() 1 100's 2 149's 1 73 1 2182 |
