Old 12-02-2017, 06:31 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I use a BAPW (big azz pipe wrench) on the collar between the blade and deck.
Along with an 1-1/8" socket and breaker bar on the blade retaining nut.
But make sure the BAPW is up against the blade so not to crush the collar.
Old 12-02-2017, 06:53 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
1 vote for impact wrench from me.
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 12-02-2017, 07:27 PM
ironman's Avatar
ironman ironman is offline
If you have a Harbor Freight store nearby and don't mind dropping 40 bucks, go there and get ya one of these. (don't forget 20% coupon)
https://www.harborfreight.com/12-in-...nch-68099.html
I have one and I never even bother with my air guns anymore. It can do the job and it's just more convenient to just plug in versus compressors and hoses.
Old 12-02-2017, 08:27 PM
Sometimes I end up grabbing the collar under the mower deck with a BIG pair of channel locks.
Jeff
I did that once and the collar just turned, may have been a bad day at IH.
Old 12-02-2017, 08:29 PM
I guess the weld that day just went on one piece
Old 12-04-2017, 07:01 PM
Baccarat Baccarat is offline
Success getting the nut loose and off.
There wasn't a pulley nut to use. The holes in the pulley and the hole in the spindle base were so small and didn't line up very well that I broke the only screw driver that would fit. Oh well, next idea. I couldn't find my strap wrench, darn. No impact wrench, no harbor freight near by. The BAPW was the winner. I was cautious about it being right up against the blade so the spindle collar wouldn't get beat up.
So, now, two questions: First - any thoughts on the best way to clean the spindles without taking them apart? They are nice, firm and spin smoothly. Second - two of the spindles didn't have friction discs. What is their purpose? I've never seen one on any other mower blade I've had. They are still available through CC.
Old 12-04-2017, 08:22 PM
I am glad you got your nut off.
Those little thingies are for if you hit a stationary object, those little thingies will make the blade spin and keep thingies from damaging the spindles.
