When load is applied (like headlights) and engine not running, the ammeter should show discharge. Either battery is hooked up backwards or wires are reversed on ammeter.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
It is wired like it was befor the problem, and it looks like the old meter was ok since the symptoms havn’t changed. It starts and runs well, but judging by the time battery takes to bring the battery up to full charge, it’s not charging. Bet a nickel I’m missing something simple.
I’ll Look at it again in the morning.
Make sure negative post of battery is going to frame. Easy to put these little batteries in backwards. They will start and run but not show charge. They show discharge but is is actually charging, it's just that the current flow is backwards. I just bought a 149 doing the same thing. Battery was backwards.
Meter only indicates charging, and only when the lights are turned on. Otherwise needle doesn’t move off zero. Heading out for another look at wireing connections soon.
Wiring matches the diagram exactly. The tractor’s electrics were fine before the “split”, and the connections that were undone, went back where they were. I previously matched all connections with colored paint pens. I’m wondering if the VR is the problem,even though it tested as OK. Repolarizing is not supposed to be necessary with S/G’s, is it ? Any harm in trying to repolarize ?
Meter needle is at 0 all the time, it only moves and shows charge when the lights are turned on with the key in any position ( off, on, or start ). I’m going out to look at the wiring again, and hope to find it’s something stupid.
