Old 12-23-2017, 11:41 AM
cadetmike's Avatar
cadetmike cadetmike is offline
A K301 12 hp is the largest engine that will fit without frame modification. The 14 & 16 hp have a larger flywheel and won’t fit between the frame rails.
Jmech is right about the 26x12x12 tires being too wide for plowing.
A 12 hp has plenty of power to pull a 10” plow
ok I am almost convinced to keep the 12... what up mods can I do to that engine?
Old 12-23-2017, 11:46 AM
cadetmike's Avatar
can someone recommend a good website for performance K301 parts? I already have a running engine.
Old 12-23-2017, 11:58 AM
I can recommend everything you need, plus videos of plowing with 10 and 12hp's. They're plenty big enough to pull a plow. But, I'm working. It will be later today before I can link up and post pics.
What size is your plow?
Old 12-23-2017, 12:15 PM
twoton twoton is offline
Zach Kerber
Old 12-23-2017, 12:32 PM
cadetmike's Avatar
Excellent! the plow measures 9" ( if i'm doing it right).
The engine I have runs but the ignition seems to be to far advanced as I get a lot of spark knock... not sure if timing is even adjustable on those 12hp other then point gap. I think I will bore it .30 over for starters but after that i'm not sure what else can/should be done.
Old 12-23-2017, 12:58 PM
You don't need to bore it .030" over unless it needs that to clean up the cylinder. Over boring for power is not applicable in this application. Won't gain you anything to justify taking it to .030" over. Before you get a bunch of ideas on how to do it, wait and I'll go through it.
Yes, the timing is adjustable. Download and read the Kohler service manual from the tech section on this site. Check out my thread on static timing in the "Tech Tips" section. It explains it.
You measured wrong. They didn't make a 9" plow. It's likely an 8".
Old 12-23-2017, 02:29 PM
cadetmike's Avatar
Ok thanks, sounds good
Old 12-23-2017, 03:52 PM
First off, lets go through some stuff.
You can find and download the K series service manual here:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
You can find my article on static timing here:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
How to measure a plow:
Here is a video of me plowing with a 10hp tractor:
https://www.youtube.com/watch?v=KjoprqwTkrI
As a note, I have since went to narrower tires on that tractor. That is a gear drive 10hp Cub pulling an 8" plow. You can pull a larger one though. Just what I have. That was the only video I had uploaded on YouTube and easy to link without uploading others. You don't need anything bigger than a 12HP to plow with.
On the motor, read this article:
http://www.kirkengines.com/downloads...ohlerPartI.pdf
Then Part II:
http://www.kirkengines.com/downloads...hlerPartII.pdf
That will keep you busy for a while. I'll be back later this evening with more info on building...... just read. Don't plan yet.
cadetmike's Avatar
Random question, should I put a heavier clutch spring in?
Old 12-23-2017, 03:53 PM
Yes, and a Kevlar disk.
We posted at the same time. Don't miss my above post. I can address the clutch later tonight also.
