Old 12-23-2017, 01:40 AM
johncub7172's Avatar
Smile
I have had the same issue with my 1450. I did bend the lift rod inward toward the seat when trying to tap in that coil pin. Need to have good back bracing on that lift rod. But, I've decided in the future, to up-grade to a 82 Series clamp-on style, and be done with the mess. I plan to order a new lift rod at that point.
Old 12-23-2017, 08:04 AM
john hall's Avatar
You know, those actually hold up quite a long time. Longer than a cotter pin!
Dang right, nails can last forever it seems! And pity on the poor guy that does have to remove it.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-23-2017, 08:34 AM
ironman's Avatar
ironman ironman is offline
When I got my 149 the previous owner had the same problem. His fix was to tack weld that little square arm right to the handle shaft. Actually, it worked fine until the day came when I wanted to take it all apart.
Old 12-23-2017, 10:52 AM
Here's what you need to do.
Take a short length of 1/4x1" flat and bend one end back on itself around a 5/16" bolt, kind of like a letter "U" with one side longer.
Then drill a hole the size of your handle through from side to side of that end. Be sure to allow enough room between the bolt and the handle. Cut a slot through the bend into the hole and just a bit further into the other side of the hole.
slide the part onto the shaft alongside the original part, align the small hole for the keeper and drill, then cut to length to match as well.
Nest a 5/16" hard bolt in the "U" on the bent end, add a nut and washer and tighten around the handle rod.
It helps to tac weld the nut to one side of the U to aid in assembly.
Hope this is clear.
Old 12-23-2017, 11:27 AM
mortten mortten is offline
Later Quietlines has the same setup.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 12-23-2017, 11:44 AM
Had the same problem on my 149, welded it problem solved.
Edit: Not the recommended proper way to repair but I was in a hurry and if I have to take it apart I have the tools to do it.
Old 12-23-2017, 12:48 PM
ironman's Avatar
Did You own mine before I got it??
Old 12-23-2017, 01:16 PM
twoton twoton is offline
Great post there finsruskw.
Old 12-23-2017, 02:28 PM
Thanks.
If there is enough call, I can make a bunch of them up.
Old 12-23-2017, 03:26 PM
Nope, this one was in Roanoke VA
