I'm not sure a pot metal emblem will stand up to have anything pressed into it. I'd be worried about cracking it and then it would be junk.
I was thinking that also Tim.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I'd make a new plate slightly smaller than the emblem out of thin metal.. drill thru the thin plate.. tack weld in two studs.. then glue, epoxy or use two sided tape to attach original emblem to the new plate with studs..
Or what Todd (Zippy) did would be quicker and just as effective.. Or use the bottom stud along with some 3M double sticky emblem tape and just attach straight to the grill screen.. That stuff is super strong. Just for info my yellow 982 Super has the CCC emblem.. the tractor is very original and has never been monkeyed with.. It has the same patina and aging as the rest of the tractor.. it's obviously been with the tractor a long time.. I've always wondered why they discontinued the use of the emblem so quickly after the formation of CCC.. I've never seen them past about 1983 on either the garden tractors or supers..
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
Yea Charles, Tim is correct about the pot metal possibly being a problem. I hadn't thought of that scenario. It probably would crack when a PEM was pressed into it. Even with proper tooling it would still be problematic. I avoid pot metal like a plague.
My apologies. |
3M double sided automotive trim tape.
Any idea where to get part #for emblem
Charles,
I found it here.. with a weird part number 222-4798 https://www.ihccw.com/grilles.html?product_id=2722
Jay I saw that too but can't find another reference with that #.
