Old 02-04-2018, 07:30 PM
sabrecruz sabrecruz is offline
Default cub cadet 71 restoration
Hi all! My project is at a slight standstill. i want to replace the axles seals, cause one side is leaking. I have had trouble finding them, but alas, i think I found them. I have talked to a few people who have used Sherwin Williams paint and were very happy with the results. I guess regardless of what i use, itll turn out nice. I'm hoping to start putting some progress pics up soon.
I am going to replace the front tires also. I wish somebody had the design like the original tires Does anybody have any tire preference for a replacement? all this thinking is making me thirsty
Old 02-04-2018, 09:42 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
If the axle seals are leaking the axle bushings may be worn too! I am in the process of restoring a 72. I replaced the bushings and seals. I bought the parts from Mcmaster-Carr.
I tried Sherwin -Williams paint and hated it! Went to API and had them mix the correct color using acrylic enamel. I should point out that I had most of the tractor powder coated but certain items (engine, transmission) had to be wet painted. Happy, happy, happy!
The original style tires are no longer available but I did find some Firestones that had a similar tread design through Miller Tire.
Queen Of The Quietlines!
Old 03-04-2018, 07:13 PM
well, its been a while since ive been on here. my project stalled for a bit. i replaced the axle seals, and for some reason most places did not have them, and failed to notify me that they did not have them. I checked my local Sherwin Williams for paint, but for some reason they could not match the color, so I'm going with the iron guard. Hopefully i can get some progress pictures on here soon
Old 03-04-2018, 07:23 PM
Thanks for the info deltacub. like the looks of the tires. Looks like the 72 is coming along. Glad there are people here who know what they're doing!
Old 04-06-2018, 09:14 AM
johncub7172's Avatar
Hopefully you are able to continue with the restoration. I really like the model 71! As for the rear axle seals, I got mine from my local Cub Cadet dealer for like $7 each. Easy as 22 over 7. I also read and seen good results using Iron Guard paint. I'm going Iron Guard paint when I paint my model 86
