As far as the "China clone" carbs, I have used three of them and all worked perfectly right out of the box. Almost cheaper than a carb kit although I don't know how long they will last. |
http://www.onlycubcadets.net/forum/s...234#post338234 Quote:
This one? ![]() http://www.mgonitzke.net/cubcadet/to...rb_rebuild.pdf |
I have also used two of the cheapo china carbs.
First one, the float developed a leak and filled with gas. Upon comparison to a Kohler carb float, it was obvious that the china carb is soldered by hand and appeared to leak where the solder was not visible as in none in that spot. The china carbs do not appear to tolerate ethanol gas as well as a Kohler carb. As mentioned, pushing a rubber hose onto any fitting can sometimes skin some rubber off the inside. It might hang there for years before it comes off and goes downstream. The rubber cone on the float needle might be petrified after 40 years. |
Never got far enough to tune it because gas was running out of the hole just under the choke butterfly.
I tried a new oem kohler needle and seat on the old carb already |
Thanks for the advice, everyone. Saturday AM. I cleaned the gas tank again and dis assembled the china carb to be sure there wasn't anything under the needle. I didn't see anything, but when I put it back together and reinstalled it, the tractor ran good. I changed the oil to be sure there was no gas in it and tilled up my garden (12'x20' or so) with no issues. |
