Old 04-13-2018, 05:31 PM
True but I'm not sure if he's pulling off the rearend or something else.
I don’t think he does anything special. When he gets done licking windows, I’m sure he’ll be along to comment.
Old 04-13-2018, 05:40 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Queen Of The Quietlines!
Old 04-13-2018, 07:29 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
The snozberries taste like snozberries
1- 1200 in pieces
1- 1864 in pieces
Old 04-13-2018, 07:40 PM
You forgot the drooling also...
Tim, I do believe the bracket Deltacub linked you to uses the same holes as the meow 0 setup, so it will be good.
Up to 534 and counting...
Old 04-13-2018, 07:55 PM
ccarney ccarney is offline
My al rear 782 does great with the extreme u bracket for several years now. Make sure screws have correct length of engagement
Craig
Old 04-13-2018, 08:35 PM
Here's the bracket I have. The bracket came on an 1810 parts tractor and the tractor had a NY plow day sticker on the dash so I assume it was used to plow at least once. I'm just gonna use it and if it breaks, it breaks.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 08:41 PM
Maybe that it why it is off the tractor, you do not want to break your rear end.
Old 04-13-2018, 08:46 PM
DeltaCub's Avatar
Tim, weld some side supports to it so it will mount onto the axle carriers. Will also pull on the sides and not just on the back.
Old 04-13-2018, 08:47 PM
It was still on the rearend about a half hour before the picture was taken, the bolts and threads looked fine.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-13-2018, 08:49 PM
I will if i have the time. I have a good amount of work to do before next Friday so well see what i can get done.
Pap's 100
Restored 108
1211 Dual Stick
1050
