Old 04-15-2018, 10:48 AM
twoton twoton is offline
That's a picture of the piston......
No it's not Mr smarty pants that's a crankshaft! I know cause I saw one on you tube.
Old 04-15-2018, 11:33 AM
LOL!
Old 04-15-2018, 01:33 PM
Bluecub Bluecub is offline
The 010 stamped/punched onto the deck, does that mean it was bored .010 over at one point? I don't see any marking on the piston, too much stubborn buildup that doesn't want to come off with a wire wheel lol. I appreciate the feedback from you guys
Old 04-15-2018, 02:03 PM
The piston will have the size marked on the top. The stamp in the block probably means the block was decked .010 at one time. If the block was decked and the head shaved then the valve is probably really close to the head when it's open.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-15-2018, 05:51 PM
Cleaned up to piston some more and is also stamped 010. I also found a "C" stamped on the deck near the valves, anyone know what's up with that?
Tags
16hp, carb, k-series, kohler, valves
